Implementing Vlans a few questions
Todd Willoughby
Hey folks, Im getting in a new 3560X (WS-C3560X-48PF-S) switch in very shortly and Im going to be taking my single flat network and implementing Vlans (about 7 in total) Im going to be using this new 3560X switch to do the inter-vlan routing. My question is, I have a DHCP and DNS server that is going to be in the same VLAN as my users and other internal clients. Is there a way to have this server fullfill DHCP and DNS request for other VLANS that are going to be implemented on the network?
Reza Sharifi
yes, you just need to add this command to the SVIs for your other vlans.  So lets say the DHCP is in vlan 2, and you have vlan 3, 4, and 5, etc....  Under the the svi interfaces for vlan 3, 4, and 5 add this command:
ip helper-address xx.xx.xx.xx
where xx.xx.xx.xx is the ip address of the DHCP server
Reza Sharifi
Just got done reading on this command, perfect answer thanks
