Importing Configuration from a Cisco switch to a DCN switch.
As the title says, Importing Configuration from a Cisco switch to a DCN switch...
Is such a thing possible? Since the both are made from the same software engineers and the OS's are 98% identical or something.
This something is needed for me as I have one DCN switch
pieterh
if indeed "the OS's are 98% identical" then you can try just to copy the config somehow.
if your current cisco switch has an USB connector, you can use an USB-key to transfer the configuration
Cisco:  copy startup-config usbflash0:
DCN:  copy usbflash0:startup-config  running-config
          copy running-config startup-config     (or just legacy "write")
or similar depending on how the usb is named on the device
if no usb present, you need another transfer method like
- using a tftp-server
- copy paste on the CLI from one switch to the other
   do this with segments of the configuration at a time, not the whole config at once!
