03-17-2020 06:02 AM
Hey, all.
So I recently moved a layer 3 gateway from a load balancer to my 9500 distribution switch during a network redesign. This network lives in a VRF at the distribution level. The ARPs for this network, we'll say 2.2.2.0/24 are incomplete on the distribution switches with the exception for the peer switch (i.e. the distributions can see and ping one another).
However, pings do not work and I receive this error:
Distribution 1 and 2:
Distribution1# ping 2.2.2.55 vrf Stuff PING 2.2.2.55 (2.2.2.55): 56 data bytes 36 bytes from 2.2.2.55: Destination Host Unreachable Request 0 timed out 36 bytes from 2.2.2.55: Destination Host Unreachable Request 1 timed out
When I try to ping from the 9300 access layer switch to the distribution gateways I receive this error:
AccessSwitch# ping 2.2.2.1 PING 2.2.2.1 (2.2.2.1): 56 data bytes ping: sendto 2.2.2.1 64 chars, No route to host Request 0 timed out ping: sendto 2.2.2.1 64 chars, No route to host Request 0 timed out ping: sendto 2.2.2.1 64 chars, No route to host Request 0 timed out
I'm actually a little bit confused at this point. There is a trunk between both distributions and the access switches that allows the VLAN in question.
Hoping someone has a suggestion or two.
Thanks.
03-17-2020 06:33 AM
we need more information about the enviroment, how these device connection what is the ruting table information getting from.
do you see that routes are injected to routing table ?
show ip route vrf all or show ip route vrf XX should have routing information.
The host not reachable means, either host not live or no routing available for that subnet.
03-17-2020 06:42 AM
Post a diagram of how switches are interconnected, and for the interconnecting interfaces, post the output of "show spanning-tree interface f/z/z" and "show interfaces trunk".
Cristian Matei.
