info on stacking Cisco 2960-X switches
notaciscoguy
Hello all,
I am getting ready to stack a pair of 2960-X switches and I just had a quick question. One of these switches(switch A) has been configured for some time and has run out of available ports(hence the stacking). the second switch (switch B) is a clean config. Once I get switch B connected with stacking cables, do I still require an ethernet link between the two switches to pass data or will the stacking cables act as pass throughs that pass all traffic through and out the trunks already configured on switch A?
BradEast1
Level 3
Level 3
The stack cables will take care of it, no need to connect via copper
5 Replies 5
BradEast1
Level 3
Level 3
Joseph W. Doherty
As Brad notes.
The switch that you add will basically just appear as an extra bank of ports you can configure on your existing switch.
notaciscoguy
Thanks for all the info guys. I was not aware of the IOS image limitations or the mixed model limitations. Thankfully both should be using the Base image instead of Lite and both are the same model, not that I have enough cables or switches to make an 8 stack.
Glad to help. Please rate as helpful and/or resolved if you don't need anything else.
