Bookmark
Subscribe
5593
input drop other-IOS-XR
Mahesh Gohil
Level 7
Level 7
Hello Experts ,
any idea for below drop.
#sh controllers TenGigE0/3/0/0 stats
Ingress:
    Input total bytes           = 184983908201609
    Input good bytes            = 184983908193483
    Input total packets         = 476570253226
    Input 802.1Q frames         = 0
    Input pause frames          = 0
    Input pkts 64 bytes         = 1051589535
    Input pkts 65-127 bytes     = 198638861313
    Input pkts 128-255 bytes    = 113898515084
    Input pkts 256-511 bytes    = 54986973113
    Input pkts 512-1023 bytes   = 39923316859
    Input pkts 1024-1518 bytes  = 41648349441
    Input pkts 1519-Max bytes   = 26422647884
    Input good pkts             = 476570253212
    Input unicast pkts          = 476567711194
    Input multicast pkts        = 2542016
    Input broadcast pkts        = 2
    Input drop overrun          = 0
    Input drop abort            = 0
    Input drop unknown 802.1Q   = 0
        Input error giant           = 0
    Input error runt            = 0Input drop other            = 3920127
    Input error jabbers         = 0
    Input error fragments       = 0
    Input error CRC             = 12
    Input error collisions      = 0
    Input error symbol          = 0
    Input error other           = 2
    Input MIB giant             = 0
    Input MIB jabber            = 0
    Input MIB CRC               = 12
#sh interfaces TenGigE0/3/0/0
     60298924302 packets input, 25287858986470 bytes, 70389 total input drops
     0 drops for unrecognized upper-level protocol
     Received 0 broadcast packets, 298092 multicast packets
              0 runts, 0 giants, 0 throttles, 0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     69305800973 packets output, 29793241284072 bytes, 0 total output drops
     Output 0 broadcast packets, 309639 multicast packets
     0 output errors, 0 underruns, 0 applique, 0 resets
     0 carrier transitions
Mahesh
Yigal Dekalo
Is this drop rate is a concern?
What is the plim type?
What's going on the other ports on that plim?
Have you tested L1?
Can u get the plim asic stat?
Mahesh Gohil
Level 7
Level 7
Hello Guys,
Any idea ?
This is happening with almost every gig interface for node migrated to IOS-XR. But yes there is no customer complaint.
Mahesh
Yigal Dekalo
Have you tested L1?
Hello Yigal,
Nice to know that you are active on community .
Well answers to your questions.
     > No. And that is the reason I did not log tac case and prefer to get answer from community.
     > SPA-1X10GE-L-V2
      > Port is admin down (Teng0/6/1)
Have you tested L1?
      > Yes, 24 hour test without any issue found.
      > command (sh controllers plim asic statistics interface <>) is not working since this is GSR.
However I am sharing few command output of one of the node which might be useful.
Mahesh
Hi everyone,
Logged tac case with cisco and as per Tac the problem could be because of Bug:CSCti75606.
Desc: Input drop counter increaing in output of show interface eventhough there is no actual drop observed.
This will be fixed in 3.9.3 version. Thanks Yogal for valuable time.
Mahesh
