Input is more than output??
dfce
Frequent Visitor
Frequent Visitor
Hallo ,
i have 2 Catalyst Switches and they connected directly together, if i look at the output Packets on the interface of switch 1, i see 1973 gb output.
but on the other Side (Switch 2) the input of connected Switch 1 interface is much more 8036 Gb. is this normal and, why?
balaji.bandi
Can you post the output to understand : ( In general I have observered may not be all the case or may be the case same)
 depends on who is intiating traffic and who is deliverying the traffic (it defined as input and output, where they connected to)
take example :
if you see when the device connected to Internet, Output  (inside to outside internet) you see less compare input from (internet to inside)
BB
Hallo
