input output packets are not showing in VLAN
navinder.singh
Input and output packet are not showing in VLAN 41 of Cisco WS-C4510R-E (MPC8548)Switch, IOS cat4500e-entservicesk9-mz.122-52.SG.bin. However the nodes connected via VLAN 41 are able to communicate with others nodes in VLAN 41. Below is the VLAN status. Attached is the Tech-Support.
Fourth_Flr_User_Switch#sh int vlan 41
Vlan41 is up, line protocol is up
Hardware is Ethernet SVI, address is 0025.8466.427f (bia 0025.8466.427f)
Internet address is 172.20.41.3/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not supported
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 01:09:59
Queueing strategy: fifo
Output queue: 0/40 (size/max)
L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
L3 out Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
  0 packets input, 0 bytes, 0 no buffer
  Received 0 broadcasts (1334 IP multicasts)
  340 packets output, 15942 bytes, 0 underruns
  0 output errors, 0 interface resets
Calin C.
Level 5
Level 5
 However the nodes
41
The device are connected in the same switch and are in the same vlan (41) ?
Then it's normal that you don't see any traffic. You are checking a L3 interface there, but if the devices are in the same vlan they are switching the packets in the L2, so the packets are not travelling through SVI interface.
You can even have not interface VLAN41 and the devices in the same vlan will be able to communicate to each other.
Only packets from devices in VLAN41 to and from any other VLAN will be seen into the statistics of SVI interface.
Let me know if this helps.
