inserting GLC-FE-100LX in to 2960S SFP slot
devaprem12
Based on following Scenario
we have 3750 (WS-C3750-24FS) core switch connected to 2960S Edge Switch (GLC-FE-LX)
Is it wise to connect 3750 having 100 Mbps MTRJ fibre with 2960S SFP( GLC-FE-100LX)
Is it possible to use SFP GLC-FE-100LX with 2960S switch
Thanks and Regards
Deva
andtoth
Level 4
Level 4
According to the Table 8 in the Cisco 100-Megabit Ethernet SFP Modules Compatibility Matrix, GLC-FE-100LX is supported in the 2960 and 2960S switches. You will need to use at least IOS version 12.2(53)SE1 in order to be able to use that SFP module. See the link below.
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL632702.html#wp63326
Best regards,
Andras
