rate limitation
network770
Can someone explain to me how rate limitation works on an interface or vlan:
policy-map abc
  class def
   police 3072000 384000 384000    conform-action transmit     exceed-action drop     violate-action drop
how is qos differ than rate-limit?
how do i rate limite an interface to get say 2MG to the Internet?
Is there a need for queing?
I looked over the cisco qos doc and there's far to much info there, I am looking for the 'crash course'
Haris P
Level 4
Level 4
Dear Ronni ,
To rate-limit the traffic on the link , I prefer to do shaping
policy-map 2Meg
class class-default
  shape average 1024000
int f0/0
service policy output 2Meg
The difference between policing and shaping is described in the below linl
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a00800a3a25.shtml
Please let me know which platform you are using
Hi Ronni,
See the below rate limit implementation.
Rate limit on an interface:
Router# conf t
Router(config)# int gi3/34
Router(config-if)#rate-limit input 1000000 187500 375000 conform-action transmit exceed-action drop
Rate limit on an vlan interface:
Policy a specific VLAN number on VLAN interface.
class-map vlan5
match vlan 5
match class-map class-default
policy-map vlan5-limit
class vlan5
police 2000000 250000 exceed-action drop
int vlan5
service-policy input vlan5-limit
After you apply this configuration, the traffic with VLAN 5 coming from any will be policed at 2Mbps.
Hope this will help you.
Please rate the helpfull posts.
Naidu.
andtoth
Level 4
Level 4
QoS highly depends on the platform you are using. For example, Catalyst switches does not have the rate-limit command (although sometimes configurable in CLI, will not do anything).
You can rate limit traffic with the policy-map you've included (if the traffic matches the configured class-map) by applying it on an interface with the 'service-policy abc' command under interface configuration mode. Note that some Catalyst switch platforms allow a policy-map to be applied in the input direction only.
Best regards,
Andras
