Installing L3 License Nexus 5548
Patrick McHenry
Level 4
Level 4
I have my license file ID - now I need to activate it. Does anyone know a good link for the step by step install?
I have this link:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/nx-os/licensing/guide/b_Cisco_NX-OS_Licensing_Guide_chapter_01.html#task_24958
Not sure what it is askiing me to do. Where is says "switch# install license bootflash:license_file.lic"
Should I put the LicFileID in place of the license_file?
Also, I've heard that the L3 daughter card requires a Lan Base license as well and sometimes it is not included in the L3 daughter card. Must I install the Lan Base as well?
Thank you, Pat.
Reza Sharifi
Hi Pat,
That is correct.  You put the license file name where "license_file.lic" is located.  The license file name usually has .llc as the extension.
If you have an enterprice lisence, it shoud work with L3 card.
Leo Laohoo
Once you install the Layer 3 card, the Layer 3 licence is included. You'll need to just enable the license via CLI.
Sent from Cisco Technical Support Wii App
Thanks Leo - what is the command to enable the license?
Thank you
You would need to enable the features that require the layer 3 license such as feature eigrp, feature ospf etc.
