Integration of Cisco Core Switch 3850X and Cisco Access Switch C1000
Herald Sison
Level 3
Level 3
Hi Everyone,
i tried integrating 2 switches for office use Cisco Core Switch 3850X and Cisco Access Switch C1000 via copper uplink ports, when i tried to connect the two switches the whole network experienced some weird lag and slowness in the network performance.
is there something wrong with my configuration,
core side port config:
interface GigabitEthernet1/0/44
description UPLINK to ACC-SW01
switchport mode trunk
i already have a static route from my core switch to my firewall and it is working fine,
ip route 0.0.0.0 0.0.0.0 172.21.1.1
access side port config:
interface GigabitEthernet1/0/48
description UPLINK from Core
do i need to add static route from my access switch to core switch?
thanks to anyone who can help me sort this out.
more power to all!
balaji.bandi
This may be due to STP i guess, Make sure your Core Switch 3850 have higher ATP priority
what is the logs you see omn both the devices ?
BB
