Inter-VLAN Routing and VTP Domain
Tang-Suan Tan
Hi all :
I have a question that how to inter connect certain VLAN to certain VLAN? I just only want to use inter VLAN routing and no Private VLAN Routing.
For example, I have 6 VLAN : VLAN 1 to VLAN 6.
The requirement :
VLAN 1, VLAN 2 and VLAN 3 are inter routing each other.
VLAN 4 and VLAN 5 are inter routing each other.
VLAN 6 is stand alone VLAN without any routing.
Below is my steps, please give me advice, correction and suggestion if you have any:
First, I have to creat 6 VLANs : VLAN 1 to VLAN 6.
Second, I creat VLAN 1 to VLAN 3 in VTP Domain 1.
Third, I creat VLAN 4 and VLAN 5 in VTP Domain 2.
Fourth, I creat VLAN 6 in VTP Domain 3.
Fifth, I use interface VLAN command to set inter VLAN routing of all the 6 VLANs.
After the above 5 steps, can the network works as per my above three requirements? Any better idea or any problem on above steps?
Thanks and best regards,
tangsuan
6 Replies 6
Giuseppe Larosa
Hello Tang-Suan,
configuring different VTP domains has no influence on IP connectivity, it just provides 3 different administrative domains for configuration and propagation of Vlans on a population of switches.
If you build a trunk manually between switches in different VTP domains layer 2 and layer3 communication can take place.
To build separate routing tables so that different sets of SVI interfaces route between them you should use VRF lite.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/vrf.html
You need two VRFs
ip vrf DOMAIN1
rd 1000:100
ip vrf DOMAIN2
rd 1000:101
int vlan 4
ip vrf forwarding DOMAIN1
! retype ip address and mask
ip address x.y.z.k 255.255.255.w
int vlan 5
ip address x5.y5.z5.k5 255.255.255.w
int vlan 6
ip vrf forwarding DOMAIN2
ip address x6.y6.z6.k6 255.255.255.w
show ip route vrf DOMAIN1
ping vrf DOMAIN1
are the commands to be used to see the different IP routing tables and to test IP connectivity in VRF
Hope to help
Giuseppe
if we have VTP for vlans to comunicate  in our network why we use routing inter vlans?
randerson
VTP is really only intended to distribute vlan information between switches, not necessarily limit routing between vlans. Inter-vlan routing is really controlled via ACLs on the L3 vlan interfaces, so if you are routing on your core switches, for example, you would block routing between the associated VLAN's subnets.
You can certainly separate switches into different VTP domains but that only limits which vlans get inserted into the switch's VLAN database - it does not preclude a device connected to that switch from being able to connect to another VLAN provided that the uplink trunk is allowing that VLAN.
Your steps above are fine for minimizing VLANs on certain switches but you'll need ACLs on the VLAN SVIs (switch) or sub-interfaces (router) if you want to limit traffic between VLANs. If you don't want any routing at all, you won't have an SVI or sub-interface for that particular VLAN so that only ports on VLAN 6 will be able to communicate with one another.
Hi Ross and all:
Thanks to your reply!
After your suggestion, I went on to study the VLAN ACCESS CONTROL from Cisco website. I have gained the knowledge how to implement it but I have one question below.
As the VLAN ACCESS CONTROL can block different subnet and so at the same time it applies to different VLAN if the VLAN represents by the same subnet. The problem is where are the switches this VLAN ACCESS CONTROL applies ?
For exaple as for  typical Cisco Hierarchical Network, all the different VLAN scattering on different access switches under different distribution switches.
The same requirement that VLAN 1, 2, 3 are inter-routing each other while VLAN 4, 5 are inter-routing each other.
After I create the access lists and then create the VLAN access maps for all the requirement. How do I apply the vlan access maps to the switches?
Are the VLAN access maps to be applied on all the access layer switches since different PC in different VLANs will pass through the access layer switches in the first place before the distribution and core switches?
Or I can apply to one of VTP server (for example at one of the core layer switch), then this VTP server will propogate the VLAN ACCESS MAP to all the switches (in VTP client mode)?
Please help to provide your advise if you or anyone know the answer.
Many thanks!
best regards,
tangsuan
Make new post
MHM
Hello
You only require a single vtp domain and at the very least one l3 switch/rtr ruining the intervlan routing, two L3 switchs/rtrs  if you would like resilience
Pvlans are  a feature to isolate shared ip range(s) within a network which is a viable solution to negate access for certain hosts  however if you which to negate access between vlans Routers Access Control Lists (RACLs) would be bettered suited for your requirements
see attached file for an example of a basic L3 switch running  the interlvan routing and a L2 switch that would attach to the network.
Kind Regards
Paul
