12-14-2016 02:07 PM - edited 03-08-2019 08:34 AM
I have attached the document with set up for reference.
I can ping from PC in one VLAn to another but not the other way around, please see the attached document with layout.
Not sure what am I missing here.
Thank you very much.
Solved! Go to Solution.
12-19-2016 10:40 PM
As I seen your switches configuration, Switch A is working as Layer 3 switch, where you performing Intervlan routing.
My Suggestion as:
Please set the default gateway of all your PC / Desktop / Laptop etc. as below
Devices which are in VLAN 1
Gateway 10.6.0.1
Devices which are in VLAN 2
Gateway: s 10.6.2.1
Devices which are in VLAN3
Gateway: 10.6.3.1
And remove one command from your switch A
Witch typing following command: (If this command will not working then you should disable IP routing first and after that type again.)
no
Deepak Kumar
12-20-2016 10:05 AM
Deepak,
I already had all configuration set up on pc's as you can see in spreadsheet. I just removed the default gateway also. But no luck.
