Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco VSS dual-active fast-hello not supported
Nishit Bhosale
I have Cisco WS-C4510R+E with sup WS-X45-SUP7-E. IOS version on this switch is cat4500e-universal.SPA.03.04.05.SG.151-2.SG5.bin . Enterprises license is permanently installed on switch. I have configured VSS on this but i am not able to configure dual-active fast-hello on L2 link. only dual-active detection using PagP is supported. since we don't have neighboring devices support PagP. I want to use dual-active fast-hello using L2 links between two VSS switches.
I believe dual-active fast-hello on L2 link is supported on Release 3.6.1E. Please confirm whether i will have to change current IOS release from 3.4.5SG to Release 3.6.1E to support dual-active fast-hello link.
I also want to know what will be major features change if I upgrade current IOS release from 3.4.5SG to Release 3.6.1E
alessandro.s
dual-active fast-hello is supported from release 3.5.0
(reference link: http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_29985-01.html )
so is also supported in release 3.6.1 .
You can see all feature changes in release notes for version 3.6.X
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_32143-01.html#pgfId-2657932
Best Regards,
Alessandro
