Inter VLAN Routing
Mark Bowyer
Level 3
Level 3
I am pretty sure this is the case, but for inter vlan routing the work properly, does there need
to be an IP address set on the VLAN interface? I am fairly sure there does need to be
as it would not know where to route the traffic to otherwise as I dont think the traffic is tagged until it reaches the trunk.
Nagaraja Thanthry
You are correct. You need an IP on the VLAN SVI (virtual interface) to acheive InterVLAN routing (if you are using a Layer 3 switch). If you are using a Layer 2 switch, then you need a router to do InterVLAN routing.
interface VLAN 1
ip address
exit
interface VLAN 2
ip address
exit
ip routing
Please make sure that all devices in the VLAN point to these two addresses as their default gateway respectively.
Hope this helps.
NT
Nagaraja Thanthry
interface VLAN 1
ip address
exit
interface VLAN 2
ip address
exit
ip routing
Hope this helps.
NT
I just read over your post again. It is actually a 3750 that I am talking about which is a layer
3 switch. So you are saying that I would need to assign an IP address on every vlan that I need to route somewhere? On a router you would need to create sub interfaces and tag each sub interface?
Yes, that is correct. That IP address will act as default gateway for all
the hosts in the VLAN.
NT
