Interface Description Script
k.joslin
Does anyone know of a script that can be run in IOS to automatically add descriptions to switch ports using DNS?  We are trying to clean up years of bad documentation and adding port descritions is one thing we are trying to tackle.
hobbe
Level 7
Level 7
I have heard of a script like doing things similar to that of what you are asking.
I think it is quite possible to do just that with the help of EEM and TCL scripts.
There is a community that handles EEM/TCL specifically.
https://supportforums.cisco.com/community/netpro/private/pilot/eem
and there are several good scripts there already maybe you can modify one of them to suit your needs.
Good luck
