Interface Explanation Doc
jonhill
Level 3
Level 3
Is there a PDF around that explains the meaning of all the different parts of the sh int command ie what a Input and output drop is, what an interface reset is, what a throttle is etc I'm trying to troubleshoot an issue were seeing and would like to understand all the different int error conditions.
The command : show ip interface http://www.cisco.com/en/US/docs/ios/12_3/ipaddr/command/reference/ip1_s1g.html#wp1096472
and the command show interface with the show interfaces switchport Field Descriptions
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_see/command/reference/cli2.html#wp3339500
I hope this helps.
Best regards.
Massimiliano.
Thanks for the links, but they don't describe any of the meanings for the output from show ip interfaces, what I'm looking for is a file that lists the meanings for things like throttles, input drops, output drops, CRC etc so I can understand what these mean and how to look at resolving them.
Jon
