Port-Channel Issue
bbinion80
Greetings,
I am having a weird issue with a port-channel interface. I am configuring a trunking interface to link up a switch with a VMWare ESX Server virtual switch. I have set up the trunking on the virtual side as well as on my physical switch. I am using 2 ports to create this channel. The problem is when I set up a continous ping from my Windows system, and monitor I am seeing some interesting results. When I add both ports to the channel, communication stops. When I remove one, communication starts up again through the port not in the channel. When I shutdown the port channel for several mins and open it up again, the pings go on for about a min before timing out. I am not sure whats going on. The channel configs match the physical interface configs. I would assume the trunking is set up correctly since it does work when not in the channel. Any help would be appreciated.
6 Replies 6
bbinion80
Also...here are the configs from all interfaces.
Switch#show run int g1/44
Building configuration...
Current configuration : 289 bytes
interface GigabitEthernet1/44
description exstest3 (Po40 Member)
switchport
switchport trunk native vlan 22
switchport trunk allowed vlan 20-22,220
switchport mode trunk
switchport nonegotiate
no cdp enable
spanning-tree portfast trunk
end
Switch#show run int gi2/1
Current configuration : 288 bytes
interface GigabitEthernet2/1
switchport
no cdp enable
end
Switch#show run int po40
Current configuration : 274 bytes
interface Port-channel40
description Trunk to ESXTest3
switchport
shutdown
end
Brian,
You don't have the physical interfaces applied to the port channel. Try adding this to both interfaces Gi 1/44 and 2/1.
channel-group 40 mode on
HTH,
Mark
*Don't forget to do a "no shut" on int po40*
My apologies, to get the link up and working, I removed them. But when I had it set up, I did have the "channel-group 40 mode on" command applied to the two physical ports.
The interface configs look fine. Have you configured and verified the port channel on the server is configured properly?
Well we teamed the NIC's using the VM software. The team appears to be working fine. As I said, the port channel is the issue because when I pulled the ports our of the channel, the links come up with no problem. That leads me to believe the configuration is set up correctly. I am hoping that maybe I am missing something small but I am clueless.
hey brian, try various load-balancing options on the ESX side, I have had issues in the past with port-channels connected to ESX machines, go into the VMNics properties using the GUI and try load balancing using IP-source-destination or something along those lines, havent looked at it for awhile!
good luck
