Interface leaving a portchannel
william.briere
I have a portchannel with two interfaces and one of them has all of a sudden left the portchannnel... Not sure why so any help would be appreciated...
Here is a "sh log" on each...
4507:
000284: Jul 29 12:59:21: %EC-5-UNBUNDLE: Interface GigabitEthernet3/37 left the port-channel Port-channel2
000285: Jul 29 13:00:11: %EC-5-BUNDLE: Interface GigabitEthernet3/37 joined port-channel Port-channel2
000286: Jul 29 13:00:12: %EC-5-UNBUNDLE: Interface GigabitEthernet3/37 left the port-channel Port-channel2
000287: Jul 30 00:33:58: %EC-5-BUNDLE: Interface GigabitEthernet3/37 joined port-channel Port-channel2
000288: Jul 30 00:34:12: %EC-5-UNBUNDLE: Interface GigabitEthernet3/37 left the port-channel Port-channel2
000289: Jul 30 00:34:20: %EC-5-BUNDLE: Interface GigabitEthernet3/37 joined port-channel Port-channel2
000290: Jul 30 00:34:42: %EC-5-UNBUNDLE: Interface GigabitEthernet3/37 left the port-channel Port-channel2
000291: Jul 30 03:34:08: %EC-5-BUNDLE: Interface GigabitEthernet3/37 joined port-channel Port-channel2
000292: Jul 30 03:34:09: %EC-5-UNBUNDLE: Interface GigabitEthernet3/37 left the port-channel Port-channel2
000293: Jul 30 03:42:29: %EC-5-BUNDLE: Interface GigabitEthernet3/37 joined port-channel Port-channel2
000294: Jul 30 03:42:41: %EC-5-UNBUNDLE: Interface GigabitEthernet3/37 left the port-channel Port-channel2
000295: Jul 30 03:48:14: %EC-5-BUNDLE: Interface GigabitEthernet3/37 joined port-channel Port-channel2
000296: Jul 30 03:53:59: %EC-5-UNBUNDLE: Interface GigabitEthernet3/37 left the port-channel Port-channel2
4948:
19:58:43: %EC-5-UNBUNDLE: Interface GigabitEthernet1/1 left the port-channel Port-channel1
19:59:33: %EC-5-BUNDLE: Interface GigabitEthernet1/1 joined port-channel Port-channel1
19:59:34: %EC-5-UNBUNDLE: Interface GigabitEthernet1/1 left the port-channel Port-channel1
1d02h: %SYS-5-CONFIG_I: Configured from console by vty0 (192.168.65.26)
1d07h: %EC-5-BUNDLE: Interface GigabitEthernet1/1 joined port-channel Port-channel1
1d07h: %EC-5-UNBUNDLE: Interface GigabitEthernet1/1 left the port-channel Port-channel1
1d10h: %EC-5-BUNDLE: Interface GigabitEthernet1/1 joined port-channel Port-channel1
Here is a "sh int gix/x status" on each...
4507#show int gi3/37 status
Port Name Status Vlan Duplex Speed Type
Gi3/37 Grouped with port3 notconnect 75 auto 1000 10/100/1000-TX
4507#show int gi3/31 status
Gi3/31 Grouped with port3 connected trunk full 1000 10/100/1000-TX
4948#sh int gi1/1 status
Gi1/1 notconnect 1 auto 1000 10/100/1000-TX
4948#sh int gi1/2 status
Gi1/2 connected trunk full 1000 10/100/1000-TX
7 Replies 7
Edison Ortiz
This can be a Layer 1 issue, have you inspected the cables are properly seated ?
Yes the cables are seated correctly...
One thing I have noticed through further investigation is port 1 on the 4948 is now a member of Vlan 1 again??? Not sure why that would just happen on its own...
The notconnect implies physical problem indeed.
Anyway if you configure etherchannel there are some parameters must be identical on both sides (speed, duplex, allowed vlans in case of trunk ports bundled). Has this ever worked before, because it looks one port in trunking and the other in access mode.
Can you post the config of both sides?
Krisztian
William...can you post the configurations of the ports, it would be easy to suggest.
Here it is... I even switched from port 1 to port 3 and no dice... To answer the other question, yes it did work...
Both 4507 ports involved:
interface GigabitEthernet3/31
description Grouped with port37 To VMWARE In Lab
switchport access vlan 75
switchport mode trunk
speed 1000
duplex full
channel-group 2 mode on
interface GigabitEthernet3/37
description Grouped with port31 To VMWARE In Lab
speed 1000
duplex full
Both 4948 ports involved: (remember I switched to port 3 now)
interface GigabitEthernet1/2
speed 1000
duplex full
channel-group 1 mode on
interface GigabitEthernet1/3
speed 1000
duplex full
These ports are configured as trunked. When they are in disconnect state, they fall back to their native Vlan, which by default is Vlan 1.
What you are seeing is normal.
Can you replace the cable and/or SFP connectors (if any) between these switches ?
You can experiment and swap the connectors/cables between the 2 links (the ones that work vs the non-working one) and see if the problem follows the connectors/cables.
HTH,
It was a layer 1 issue. I pushed on the back of every cable (it is patched in three different places) and the port is now backup, and once again a member of the port-channel. The cable was plugged in but could 'ever so sligtly' wiggle within the jack.
