Interface Line Protocol Flapping withtin LACP/Pagp Etherchannel
moritz.orphall
Hello there,
suddenly some TenGigabitEthernet interfaces on an uplink of an access switch (C9200l-48P-4X ver. 17.3.4b) begin to flap, which means that the line protocol goes down and up again after approx. 2 seconds. The uplink leads towards an distrubition router (C9500). Those interfaces operate in an etherchannel of 2 links.
When removing interfaces from the etherchannel and let them operate as standalone, the flapping stops immediately. Thats why I would exclude a layer 1 problem like a faulty patch cable, bad gbic etc....
We have almost no input errors/CRC on counted on the concerning interfaces.
The log does not give any more information about possible causes:
021047: Jun  7 09:13:14 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/19, changed state to down
021048: Jun  7 09:13:16 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/19, changed state to up
021049: Jun  7 09:13:56 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/19, changed state to down
021050: Jun  7 09:13:57 CEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/19, changed state to up
I would be thankful for every help.
21 Replies 21
Mark Elsen
   - Can you check logs on the  distribution router too. Also check interface  counters, CRC  on that device equally.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Logs on the distri router are equal to the ones on the access switch. Just a flapping line protocol on the interfaces.
About 100 input errors a day can be find on the interfaces, which should not cause the links to go down.
  - Could you try changing  , or use another then the current or default load balancing algorithm for lacp , check if that can help.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
check the show interface status,
when it down do you see err-disable ?
The Interfaces does not become err-disabeld, only line protocol gets down and after 2 seconds up again.
there are two end of the port channel, both end check
check the err-disable,
  Logs does not say much about the problem. What I suggest is for you enable debug on the 9200 side with the command:
debug lacp  all
debug pagp  all
Hopefully this can give more information about the problem.
balaji.bandi
is this stack ? what is the other side error ?
Can you post configuration both the sides ?
show run interface port-chan X
show run interface x/x
show interface x/x
BB
interface Port-channel4
switchport trunk native vlan x
switchport trunk allowed vlan x-y
switchport mode trunk
switchport nonegotiate
Interface of Access Switch:
auto qos trust dscp
channel-group 6 mode active
service-policy input AutoQos-4.0-Trust-Dscp-Input-Policy
service-policy output AutoQos-4.0-Output-Policy
Interface of Distribution Router:
auto qos trust dscp
            - Does the problem persist when the QoS-related commands are not used ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
I removed the qos-related commands. Lets see if something changes
Line Protocol is still flapping, i removed the qos statements from the portchannel and the physical interfaces.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Unfortunately i does not help. I have choosen src-dst-ip as load balancing mechanism for the portchannel.
