Cisco 881 router has problem late collision error
nyein chan tun
Hi all,
      I faced the problem that my cisco 881 routers has configure already and line is up between ISP , and also can use internet from internal users.
But when i checked on the router, every 10 secs i found that error messages.
Feb 23 05:43:28.047: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(4), Lat
Feb 23 05:43:29.679: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(4), Late collision
Feb 23 05:43:29.723: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(4), Late collision
Feb 23 05:43:29.727: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(4), Late collision
Feb 23 05:44:25.419: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(4), Late collision
Feb 23 05:44:33.563: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(4), Late collision
Feb 23 05:44:34.015: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(4), Late collision
Feb 23 05:44:46.727: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(4), Late collision
Sometime network is down and cannot bring up to network connection.
this is my IOS version.
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 29-Oct-10 00:02 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
TGSrouter uptime is 59 minutes
System restarted at 12:52:07 utc Wed Feb 23 2011
System image file is "flash:c880data-universalk9-mz.150-1.M4.bin"
Last reload type: Normal Reload
agree to comply with applicable laws and
Feb 23 05:51:09.295: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(4), Late collision
Feb 23 05:51:10.071: %PQII_PRO_FE-5-LATECOLL: PQII_PRO/FE(4), Late collision regulations. If you are unable
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. 881 (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FHK150273SN
If
Cisco
5 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO881-K9           FHK150273SN
License Information for 'c880-data'
    License Level: advsecurity   Type: Permanent
    Next reboot license Level: advsecurity
-#- --length-- -----date/time------ path
1     28461436 Mar 01 1984 00:01:00 c880data-universalk9-mz.150-1.M4.bin
2         3331 Jan 05 2011 12:27:48 cpconfig-8xx.cfg
3      2941440 Jan 05 2011 12:28:04 cpexpress.tar
4         1038 Jan 05 2011 12:28:14 home.shtml
5       115712 Jan 05 2011 12:28:40 home.tar
6      1697952 Jan 05 2011 12:28:56 securedesktop-ios-3.1.1.45-k9.pkg
7       415956 Jan 05 2011 12:29:08 sslclient-win-1.1.4.176.pkg
94633984 bytes available (33652736 bytes used)
I used IP address for WAN port fe4 and for internal, use vlan 1 with public ip range.
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  up                    up
FastEthernet3              unassigned      YES unset  down                  down
FastEthernet4              123.123.123.123 YES NVRAM  up                    up
Vlan1                      210.210.210.210  YES NVRAM  up                    up
router#sh int f4
FastEthernet4 is up, line protocol is up
  Hardware is PQII_PRO_UEC, address is e05f.b9b9.4a88 (bia e05f.b9b9.4a88)
  Description: WAN link to Singtel
  Internet address is 123.123.123.123 /30
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 249/255, txload 1/255, rxload 4/255
  Keepalive set (10 sec)
  Half-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:05, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1644000 bits/sec, 150 packets/sec
  5 minute output rate 131000 bits/sec, 132 packets/sec
     398671 packets input, 488595441 bytes
     Received 4 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     325927 packets output, 43881552 bytes, 0 underruns
     21202 output errors, 14801 collisions, 3 interface resets
     0 unknown protocol drops
     0 babbles, 261 late collision, 20983 deferred
     0 lost carrier, 0 no carrier
There has so many output errors , and I configure very simple and just use default route.
Please suggest me what should I do to solve this problem .
Thanks a lot
Roman Rodichev
Level 7
Level 7
if I had a penny for each time I see this issue, I'd be rich
your port is auto negotiated to Half duplex. This happens when one side is set to auto duplex and the other side is set to manual half or full duplex. This also happens if your port is connected to a hub. Try setting your interface to "duplex full" and "speed 100", the collisions should go away. The interface will bounce when you do this.
It works. Thanks to Cisco Community.
I'll add one minor point of clarification. This would NOT have been a big issue if the other side is manually set to half duplex. Then both sides would work correctly (albeit a little slower) in half duplex mode. It is a HUGE problem when one side is forced to full duplex and the other side is auto. Forcing a device to full means that device does not respond to duplex negotiation requests, which means the other side has to assume half duplex if it is set to auto. Really short version is "late collisions are always bad"!
