Interface numbers for C9200-48P with uplink module C9200-NM-4X
I am installing a stack of five C9200-48P switches and have two issues:
1- although C9200-NM-4X is installed in two of these switches, I cant see it in the output of "show module". Is there any command to verify the existence of this module?
GAASW02#show module
Switch Ports Model Serial No. MAC address Hw Ver. Sw Ver.
1 56 C9200-48P xxxxxxxxxxxxx xxxx.xxxx.xxxx V01 16.12.4
2 56 C9200-48P xxxxxxxxxxxxx xxxx.xxxx.xxxx V01 16.12.4
3 56 C9200-48P xxxxxxxxxxxxx xxxx.xxxx.xxxx V01 16.12.4
4 56 C9200-48P xxxxxxxxxxxxx xxxx.xxxx.xxxx V01 16.12.4
5 56 C9200-48P xxxxxxxxxxxxx xxxx.xxxx.xxxx V01 16.12.4
2- "Show module" shows 56 interfaces in all switches, even the ones without uplink module. I can see these interface numbers even for switches without uplink module. is this normal?
GigabitEthernet1/1/1 unassigned YES unset down down
GigabitEthernet1/1/2 unassigned YES unset down down
GigabitEthernet1/1/3 unassigned YES unset down down
GigabitEthernet1/1/4 unassigned YES unset down down
Te1/1/1 unassigned YES unset down down
Te1/1/2 unassigned YES unset down down
Te1/1/3 unassigned YES unset down down
Te1/1/4 unassigned YES unset down down
Seb Rupik
Hi there,
This is normal behavior, the switch is pre-provisioning the configuration elements in anticipation of a network module being used. In theory you could config all of these network module elements, but without the physical module being inserted they would be redundant.
Use the output from show inv to determine what the ports references are. In your case:
Gi3/1/1-4
Te3/1/1-4
Gi5/1/1-4
Te5/1/1-4
As you have probably noticed depending on what SPF transceiver you use in a port will determine which port config is used (Gi for SFP and Te for SPF+)
cheers,
Seb.
5 Replies 5
Mark Elsen
 - Is there anything in the logs when the module is inserted ? Is the overall power supply or supplies sufficient to include this module in the switch ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
actually, it shows in "show inventory", but I am still confused about port numbering. I can see these ports in all switches, even the ones without uplink module.
GigabitEthernet2/1/1 unassigned YES unset down down
GigabitEthernet2/1/2 unassigned YES unset down down
GigabitEthernet2/1/3 unassigned YES unset down down
GigabitEthernet2/1/4 unassigned YES unset down down
Te2/1/1 unassigned YES unset down down
Te2/1/2 unassigned YES unset down down
Te2/1/3 unassigned YES unset down down
Te2/1/4 unassigned YES unset down down
GigabitEthernet3/1/1 unassigned YES unset down down
GigabitEthernet3/1/2 unassigned YES unset down down
GigabitEthernet3/1/3 unassigned YES unset down down
GigabitEthernet3/1/4 unassigned YES unset down down
Te3/1/1 unassigned YES unset down down
Te3/1/2 unassigned YES unset down down
Te3/1/3 unassigned YES unset down down
Te3/1/4 unassigned YES unset down down
GigabitEthernet4/1/1 unassigned YES unset down down
GigabitEthernet4/1/2 unassigned YES unset down down
GigabitEthernet4/1/3 unassigned YES unset down down
GigabitEthernet4/1/4 unassigned YES unset down down
Te4/1/1 unassigned YES unset down down
Te4/1/2 unassigned YES unset down down
Te4/1/3 unassigned YES unset down down
Te4/1/4 unassigned YES unset down down
GigabitEthernet5/1/1 unassigned YES unset down down
GigabitEthernet5/1/2 unassigned YES unset down down
GigabitEthernet5/1/3 unassigned YES unset down down
GigabitEthernet5/1/4 unassigned YES unset down down
Te5/1/1 unassigned YES unset down down
Te5/1/2 unassigned YES unset down down
Te5/1/3 unassigned YES unset down down
Te5/1/4 unassigned YES unset down down
GAASW02#show inventory
NAME: "Switch 3 FRU Uplink Module 1", DESCR: "4x10G Uplink Module"
PID: C9200-NM-4X , VID: V02 , SN: xxxxxxxxxx
NAME: "Switch 5 FRU Uplink Module 1", DESCR: "4x10G Uplink Module"
Seb Rupik
Hi there,
Gi3/1/1-4
Te3/1/1-4
Gi5/1/1-4
Te5/1/1-4
cheers,
Seb.
makes sense, thanks.
pepeEL
Hi all. I am beginner in Cisco. I have a problem. I have switches C9200-48P-E in stack 4. In one switch i have module C9200-NM-4X. It is connected withc other switch in stack cisco. Nut on this module C9200-NM-4X when run command show interface status it show me that port Te1/1/1 is unknown Te1/1/1 Swiatlo notconnect 1 full 10G unknown
. Why ? On other switch with which i want connect show me Te4/0/1 Swiatlo notconnect 1 full 10G SFP-10GBase-SR
Can anybody help me step by step how connect two stack switches by fibre. Please i am beginner. Thanks
