10-05-2006 12:02 AM - edited 03-05-2019 12:05 PM
I am currently trying to discover 16 devices on a class C network. All devices are configured for SNMP and have CDP turned on. I can discover 12 out of 16 devices. The four devices that i can not discover do not show any pattern to the ones I can discover, Ie the configuration is the same, community string is correct etc. We are running two distribution switches and I have set the Distribution 2 as the Seed. I feel if i set the other distribution as another seed it will discover the other four (however I would like to get the answer why prior to doing this). Any tips/help would be appreciated.
10-05-2006 09:57 PM
Did you verify if CW is actually receiving SNMP replies from the missing devices?
You can run snmpwalk from the command prompt on the CW server:
%ProgramFolder%\CSCOpx\objects\jt\bin\snmpwalk -v 1 -c community 10.0.0.1
If the system is unresponsive, check if you have reachability from CW server using ping and traceroute.
Review your configuration. Pay attention to the management VLAN, VLAN 1 by default. Does it have (correct) a default-gateway configured?
For background information on Campus Manager ANI discovery I recommend that you read the following document:
http://www.cisco.com/en/US/products/sw/cscowork/ps563/products_tech_note09186a0080094949.shtml#s1
--Leon
* Please rate ALL posts.
PS CiscoWorks related questions can be posted in the Network Infrastructure > Network Management forum. This would give you a better chance getting quick anwsers.
10-05-2006 11:17 PM
thanks for the reply, i will give the doco a read.
Evan
