04-10-2018 11:11 AM - edited 03-08-2019 02:36 PM
I am searching whether on a nexus5548UP without any L3 daughter card the "interface vlan" command is supported.
- according to the command configuration guide, it does not require any license (but the need or not of a L3 daughter card is not specified)
- according to this post (https://supportforums.cisco.com/t5/lan-switching-and-routing/inter-vlan-routing-on-n5548p-without-l3-daughter-cards/td-p/2241651), "interface vlan" commands can be configured without the presence of a L3 daughter card but I would like to be sure it will be a supported configuration (on this post, some are saying you need the L3 card and the license but as the commands are apparently accepted, I prefer to doublecheck).
In my case I would just need to configure 1 interface vlan in order to have an IP to be the source of an ERSPAN session on my N5548UP. I will have access to a platform at the end of the week and will do some testing but if someone already has some answers ...
Thanks in advance.
04-10-2018 11:34 AM
For 5500 series, an L3 daughter card is needed to do Inter-vlan routing but if you only need one SVI with IP, it should work without an L3 daughter card.
04-10-2018 02:37 PM
