10-01-2010 03:20 AM - edited 03-06-2019 01:16 PM
Hello Cisco Support Group,
Can anybody help me to understand more about the below output from the switch interface.
5 minute input rate 42000 bits/sec, 7 packets/sec
5 minute output rate 68832000 bits/sec, 6180 packets/sec
In typical connectivity Switch connected to a Server Switch <---->Server. As per my understanding,
Input rate is the number of packets comming in from the Server to Switch Server ---> Switch
Output rate is the number of packet going to Server from the Switch Switch ---> Server
Can anybody through your thoughts on this.
Thanks in advance.
T.K
10-01-2010 04:09 AM
Hello T.K.
You're right. Input counters represent the packets received on the switch interface, and output ones the packets sent through that interface.
Anything else you asked and I didn't get it?
Calin
10-01-2010 09:21 AM
Yup just look at it from the viewpoint of the switchport and its obvious . Out from switchport is towards the server and IN is coming in from the server . This is true whether it be a switchport or L3 SVI or a routed port . Your understanding is correct.
