Showing results forĀ
Search instead forĀ
Did you mean:Ā
internet slow-down issues repeatedly
ravikiran.p
i have two broad band connections both ISP are BSNL 20mbps & 50mbps but we have allocated 20mbps for directors only for 4 members but i always get internet slow down issue please help me
network configuration........
we have 1 ISP with two different connections one is BSNL 20Mbps & 50Mbps where both are connected to single fortigate firewall 60D; from that firewall we have given one uplink to switch1 where switch1 has more than 40 device connected along with 3 printers and 2 biometric devices and then from switch1 we have given uplink to switch2 where switch2 has connected to main server, 35 systems and also we have created 2 VLAN from switch2
this is how we have configured our network
5 Replies 5
MTU size could be the culprit...
Can you post the config(s) of your device(s) ?
sure...!
what I meant was the running configurations of your devices. If you do a 'show run', that is what is needed...can you post that ?
please resolve this as fast as possible
as i'm new joinee in this company i'm finding difficult to handle
Tausif Gaddi
Config(s) of your device(s) through "show run" Command will be required to see what is actually happening.
