InterVLAN routing, 1 layer 3 switch + 2 vlans, how?
Joris Syen
Dear,
I am trying to learn about VLANs but I am struggling to get the VLANs interact with each other.
Simplified Situation:
1x Layer 3 Switch Cisco Catalyst 3560
2x PC ("Management" and "Operating")
All I want is the PCs to be connected to the Switch via Ethernet, with these VLAN definitions
Gi0/1 VLAN ID 11: Management
Gi0/2 VLAN ID 12: Operating
And then I want the switch to do the routing from VLAN 11 to 12 and vice versa, so all equipment can communicate with each other.
So what did I do:
1. #ip routing (enabling)
2. create VLANs
3. give an IP address and SNM to those VLANs (192.168.100.1 255.255.255.224 and 192.168.100.65 255.255.255.224)
4. Dedicate VLAN 11 with port 1 and VLAN 12 with port 2
5. assign IP addresses to the computers (192.168.100.5 255.255.255.224 and 192.168.100.70 255.255.255.224)
6. set the default gateway on the computers to the IP address of the coresponding VLAN.
I thought this would have been enough for it to work but I think I forgot something because when I do a ping I get
"reply from 192.168.100.1 destination host unreachable".
Do I still need to configure a routing? I most have missed something.
Can you please help me.
Kind Regards,
Joris
2 Accepted Solutions
1)sh ip int br | i vl   you must put the v of vl in capital like this  sh ip int br  | i Vl
2)
Switch#sh int G0/14 switchport
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: down
change this:
interface GigabitEthernet0/14
switchport access vlan 11
  To:
switchport mode access
plug another device in vlan 12 subnet on a port configured like this:
interface GigabitEthernetx/x
switchport access vlan 12
ping from one device to the other and it should work.
Regards.
Alain.
did you try what I suggested in my previous post ?
Regards.
Alain.
12 Replies 12
John Blakley
Joris,
Here are a couple of things to try:
First and foremost, make sure firewalls are disabled on PCs.
2. Can you ping the gateway for the pc.
3. Can you ping the other gateway for the other pc.
If you can do 3, then you're routing correctly and it's possibly something else. So, here are the steps:
Enable routing (You already did this)
You create your L2 vlan: "vlan 11 "
Create your L3 svi: "int vlan 11"
Give it an address: 192.168.100.1 255.255.255.224
And you're done. If it doesn't work from here, post your routing table.
HTH,
John
HTH, John *** Please rate all useful posts ***
Thank you it seems I did not missed a step so..., here is the more specific information.
I have very limited experience so I hope this is what you asked for:
Switch#show vlan
VLAN Name                             Status    Ports
1    default                          active    Gi0/1, Gi0/2, Gi0/3, Gi0/4
                                                Gi0/5, Gi0/6, Gi0/7, Gi0/8
                                                Gi0/9, Gi0/10, Gi0/11, Gi0/12
                                                Gi0/13, Gi0/15, Gi0/16, Gi0/17
                                                Gi0/18, Gi0/19, Gi0/20, Gi0/21
                                                Gi0/22, Gi0/23, Gi0/24
11   MES_HMI                          active    Gi0/14
12   CONTROL_TA                       active
13   CONTROL_TC                       active
Switch#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     192.168.100.0/27 is subnetted, 1 subnets
C       192.168.100.192 is directly connected, Vlan1
Switch#
I did do the "int vlan 11" ip address .... steps, but maybe they are not saved for some reason? Do I need to save them with a command? I do not know yet how I can view those IP addresses that I entered, should they be in this screen?
I am sorry if all this is disturbing it is not as simplified now anymore then above.
But since I seem not to have missed a step I will retry things.
Kind Regards,
Joris
Post following outputs:
-sh run int Vl11
-sh run int Vl12
-sh ip int br | i Vl
-sh span vlan 11
-sh span vlan 12
-sh int trunk
-sh run int G0/14
-sh int G0/14 switchport
Regards.
Alain
Hello and thank you,
These are the outputs.
Switch#sh run int Vl11
Building configuration...
Current configuration : 66 bytes
interface Vlan11
ip address 192.168.100.1 255.255.255.224
end
Switch#sh run int Vl12
Current configuration : 67 bytes
interface Vlan12
ip address 192.168.100.65 255.255.255.224
end
Switch#sh ip int br | i vl
Switch#sh span vlan 11
Spanning tree instance(s) for vlan 11 does not exist.
Switch#sh span vlan 12
Spanning tree instance(s) for vlan 12 does not exist.
Switch#sh int trunk
Switch#sh run int G0/14
Current configuration : 64 bytes
end
Switchport: Enabled
Administrative Trunking Encapsulation: negotiate
Negotiation of Trunking: On
Access Mode VLAN: 11 (MES_HMI)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Switch#
This is my test:
Attach my test computer to port 14 with this configuration:
IP 192.168.100.5
SNM 255.255.255.224
DG: 192.168.100.1
Ping 192.168.100.1 = succes
Ping 192.168.100.65 = FAIL
C:\Documents and Settings\syen.j>ping 192.168.100.1
Pinging 192.168.100.1 with 32 bytes of data:
Reply from 192.168.100.1: bytes=32 time=3ms TTL=255
Reply from 192.168.100.1: bytes=32 time<1ms TTL=255
Reply from 192.168.100.1: bytes=32 time=7ms TTL=255
Ping statistics for 192.168.100.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 7ms, Average = 2ms
C:\Documents and Settings\syen.j>ping 192.168.100.65
Pinging 192.168.100.65 with 32 bytes of data:
Reply from 192.168.100.1: Destination host unreachable.
Thank you again for helping me but I have not fixed it yet hopefully someone can help.
Kind Regards,
Joris
2)
Switchport: Enabled
change this:
  To:
Regards.
Alain.
Regards.
Alain.
Yes,
And succesfully. Thank you (both) very much!
It seems the problem was that no device was connected to the other VLAN?
Thank you very much.
I still have another question but that is out of this toppic, namely I cannot configure the ip address of VLAN 14 Management because the IP of the switch is now in default VLAN 1. So I get a conflict when trying to define the ip of VLAN 14. The switch ip address needs to be in VLAN 14. I have no idea how this is handled normally.
Kind Regards,
Joris
I don't understand exactly what is your problem ? of course yoou can't configure an SVI IP address in the same subnet as another one.Please explain further.
Regards.
Alain
The problem is that I am accessing the switch now via this ip address:
Management Interface (VLAN ID): VLAN 1
IP Address: 192.168.0.217
SN: 255.255.255.224
DG: 192.168.0.193
I configured this via http
But it is required that the ip address of the switch is inside the VLAN 14 range (which I cant even create).
VLAN IDNameVLAN IPVLAN SNDevices Range
11MES192.168.0.0255.255.255.224192.168.0.1-192.168.0.31
12TA192.168.0.64255.255.255.224192.168.0.65-192.168.0.95
13TC192.168.0.128255.255.255.224192.168.0.129-192.168.100.159
14MGMNT192.168.0.192255.255.255.224192.168.0.193-192.168.100.189
I assume therefor I need to change the setting to
Management Interface (VLAN ID): VLAN 14
IP Address: 192.168.0.192
SN: 255.255.255.224
DG: ?? This was not required for the other VLAN SVI?
But I have no idea how to do this and if this the correct way.
Sorry for my complete ignorance.
Best Regards,
Joris
pjmonline
Console into the switch.
Config t
Int vlan1
No ipaddesss
Shut
Exit
Int vlan14
Ipaddesss a.b.c.d 255.255.255.224
This should shut down vlan 1 and remove ip address from it.
Then create vlan 14 and assign the ip address to svi for vlan 14
Thank you for that answer,
EDIT console connection via hyperterminal = done.
I have no experience accessing it via the console port.
I assume doing this configuration is impossible using an ethernet port and telnet?
Do I need additional software and cables to access it via the console port?
Best Regards,
Joris
Good afternoon,
Everything above works fine now.
The only problem I still have is this:
There is a second switch, same type, that also needs to have the same VLANs and be accessible in VLAN 14.
How to do that? But I will search the internet for that also.
11MES192.168.0.1255.255.255.224192.168.0.1-192.168.0.31
12TA192.168.0.65255.255.255.224192.168.0.65-192.168.0.95
13TC192.168.0.129255.255.255.224192.168.0.129-192.168.100.159
14MGMNT192.168.0.193255.255.255.224192.168.0.193-192.168.100.189
Thanks for everything,
Joris
