InterVLAN routing issue with 2960x
Jeff Horton
Level 3
Level 3
I have the switch configured for ip routing and can do the show ip routes.. Everything looks normal but when I try to ping across vlans it does not work.. Any ideas and also I have read through a lot of other community issues but still no answers..
Thanks....
5 Replies 5
Richard Burts
We do not have enough information to be able to understand what is the problem or how to address it. You might start by explaining to us what is the topology of your network and by telling us about the device that is doing the ping and what it is attempting to ping. The output of show ip route would also be helpful. It would also be helpful if you post the configuration of the switch.
Rick
Rick
I have two vlans configured on a switch, vlan 50 and vlan 300...
int vlan 50
ip address 192.168.50.1 255.255.255.0
int vlan 300
ip address 10.5.0.2 255.255.255.0
I have ip routing turned on..
On the console of my pc (192.168.50.61) I can ping 192.168.50.1 but I can not ping 10.5.0.2..
I do a sho ip route and it shows the connected routes..
Hope the helps more...
It is now working.. Gremlins have left... I can't explain it but all of a sudden we can get traffic across vlans..
Closing this out...
Glad to know that now it is working.
Rick
Rick
The additional information is helpful but still not sufficient to enable us to identify the issue. Please post the output of show ip route on the switch. Please also post the configuration of the switch.
Rick
Rick
