Write Memory Command with no changes in active configuration
victguti
I would like to know if running the command "write memory" on an IOS device, write the active configuration to the flash even if no change has been done in the configuration. In other words, if every time one runs "write memory" there is a writing cycle on the flash memory.
Thanks and regards,
Víctor.
Victor
Yes the behavior is the same. Each time you execute either of those commands there is a write to flash. The difference in output reflects the differences in the command used. The copy command has optional parameters so that you can specify sources, destinations, and protocol to use. So when you execute copy running-config startup-config the output reflects the choice of destination and then it executes the copy while write memory does not need to identify any optional parameters and just executes the copy.
Rick
Rick
6 Replies 6
Richard Burts
Victor
Yes every time you issue the write memory command there is a write to flash.
Rick
Rick
Thanks Richard,
if instead of running "write memory" I use "copy running-config startup-config". Is the behaviour the same?
I have just realize that the command outputs are different:
SWLAB#copy running-config startup-config
Destination filename [startup-config]?
Building configuration...
[OK]
0 bytes copied in 1.887 secs (0 bytes/sec)
SWLAB#write memory
[OK]
Víctor.
Victor
Rick
Rick
Many thanks!
Victor
You are welcome. I am glad that my explanations were helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information.
Rick
Rick
balaji.bandi
yes it is. that is normal process.
BB
