IOS Features & Stacks
bradleyordner
Level 5
Level 5
Hi Guys,
Quick question. I am trying to stack the following -
3750G 12S - 12.2.53(SE2 IP Services) Running EIGRP & OSPF
with
3x 3750X 48P-S - 12.2.53(SE2 IP Base License)
Doing some research, the IP Base does EIGRP on the 3750X, does it do OSPF?
If not I will have to get licence for the 3750X?
Brad
singhaam007
Level 9
Level 9
To use advanced routing features and other routing protocols, you must have the IP services feature set enabled on the standalone switch or on the stack master.but yes you can use it
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_55_se/configuration/guide/swiprout.html
please rate if this helps
thanks
Thanks for reply, so if the 3750G was stack master, would it work or we need the 3750X with IP services as stack master?
A Cisco 3750 switch can be stacked with any other model of Cisco 3750 switches but 3750X to
Participate IP services feature set enabled other wise Basic routing functions, including static routing and the Routing Information Protocol (RIP) will be in use.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml
thanks
