IOS issue
anitachoi3
Hi experts,
Cisco 4500 serial product would be procured in the Data center. The OSPF, BGP, MSTP, RSTP, VLAN, Dot1Q ... etc to be configured on the device. There are two type of IOS, IP base and enterprise. Some vendors propose that IP base is enough to handle about protocols. Some vendors propose enterprise version because IP base IOS to be supported limited of routes. We would like to seek for your expertise to advise on which IOS to be suitable for us. Thanks
rdgs
3 Accepted Solutions
Jon Marshall
anitachoi3 wrote:
Hi experts,
rdgs
Anita
If you want BGP/OSPF then you need Enterprise Services. IP Base does not support advanced routing protocols.
You can check which features are supported with which IOS with Feature Navigator -
Feature Navigator
If you have vendors that are proposing IP Base will run BGP then you may want to point them to Feature Navigator too
Jon
Hello Anita,
Jon is right: there has been a Cisco router called C4500 but it is end of sale now
if you mean Catalyst 4500 you need the richest feature set, otherwise if it is a router your findings apply
Hope to help
Giuseppe
Mark Yeates
Level 7
Level 7
Anita,
You are going to need the Enterprise Services feature set to support the features you need. IP base will not support the advanced routing protocols you require. Please see the feature navigator for more detailed information.
HTH,
Mark
9 Replies 9
Jon Marshall
anitachoi3 wrote:
Hi experts,
rdgs
Anita
Feature Navigator
Jon
Attached please find the result I capture from the cisco web site. It seems that IP, IP plus can support BGP. Does it mean that IP base is suitable for me? or do I select the wrong items? please advise.
rdgs
Anita
Are we talking about a 4500 Catalyst switch or a 4500 router ?
If switch your search is not valid because it is for the 4500 router.
Jon
Hello Anita,
Hope to help
Giuseppe
Hi experts,
Sorry that it is vague in my preceding message, the equipment is Cat 4506. The services I required are BGP, OSPF and VLAN services. Is the IP base IOS more than enough? Please advise.
If the IPV6 is one of mandatory requirement, does ip base support it? please advise
rdgs
If you want to configure IPV6 then you should have ADVANCED IP SERVICES.
Can you paste the output of the below command
#sh module
Karuppu
anitachoi3 wrote:
Hi experts,
rdgs
Hmmm, i thought i had advised in my original post.
If you really do have vendors telling you to go with IP Base for BGP on a 4500 you might want to  consider using different vendors.
Jon
Mark Yeates
Level 7
Level 7
Anita,
HTH,
Mark
Anita, you have been around long enough to know that Cisco has a pretty easy-to-use feature navigator that will list all the technologies and protocols that a particular feature set offers.
What you need to know, besides the technologies, is the hardware platform and supervisor module that the 4500 will be using.
For example, 12.2.53-SG1 is the latest realease of 12.2 mainline IOS that supports the 4500 with a Supervisor V. With that release, there is both an enterprise version and an IP Base version. When you select one to download, there will be a link to a page that has a complete list of all the releases' features.
Log on to Cisco's website with your CCO log-in and then click on this link below. Youll see what I mean.
http://tools.cisco.com/support/downloads/go/DownloadCart.x?imageGuId=81EB297DFBB2526D21E498D0060BB6316AB86EED&action=d
Victor
