IOS Upgrade for 6509E
AndreRS
Hi All, My company want to upgrade IOS for 6509-E VSS with one VS-S720-10G on each chassis. currently it runs with this IOS s72033-ipservicesk9_wan-vz.122-33.SXI1.bin. can i upgrade it to s72033-ipservicesk9_wan-mz.122-33.SXJ10.bin ? thank you
Reza Sharifi
Yes, you can but SXI series images are now over 10 years old.  If you have enough memory and flash, you may want to upgrade to a later version.
mdieken011
I pretty much am doing the same thing.  I have 2 6509E's running VSS and need to update the code on them.  If anyone else can help that would be great.
Create a new thread and we'll be able to help.
