iOS upgrade for WS-C4948-10GE ipbase to enterprise
Lee Kendrick
I am trying to upgrade my WS-C4948-10GE from ipbase (cat4500-ipbase-mz.122-46.SG.bin) to enterprise (cat4500-entservicesk9-mz.122-54.SG1.bin) so that I can run some BGP routing. I pulled the code from Cisco, tftp'd to the switch ensured the conf-reg is correct (0x2102) and set the boot system flash command to point to the enterprise code.
on reboot the switch tries to load the new code but gets stuck at:
Port Traffic: L2 Asic Loopback ...
UNHANDLED ROMMON EXCEPTION at PC=0453ab5c
Vector=00000100 MSR=02029230 LR=0453ab24
MCSR=00000000
CISR0=00000000 CISR1=40000000
DDR_ERR_DETECT=00000000
I had also tried pulling down a different version of enterprise code (cat4500-entservicesk9-mz.122-53.SG6.bin) but I get the same issue.
Am I missing something obvious?
Many thanks
Lee Kendrick
Please ignore this - seems we need a license upgrade
I knew it'd be simple.
  Interesting post though  in earlier versions it would just let you upgrade the versions so it is good to know if you are upgrading from base to enterprise.
