C1760 won't hold configuration
Dennis Wieringa
hi,
i have a C1760, and upgraded it to max specs.
but the device doenst seem to hold the configuration i give it.
does anyone have an idea what could be wrong with it?
This is the start-up >
Sep 13 13:45:07.698: %SYS-5-RELOAD: Reload requested by console. Reload Reason:
Reload command.
System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2003 by cisco Systems, Inc.
C1700 platform with 196608 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x6647d4
Self decompressing the image : #################################################
############################################################ [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ         TYPE
MainBoard       0X00027A80 1760
                0X000F3BB0 public buffer pools
                0X00211000 public particle pools
   VPN          0X00030C0C VPN Module Buffers
TOTAL:          0X0035D23C
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 25837859 bytes to IO Memory.
PMem allocated: 142606336 bytes; IOMem allocated: 16777216 bytes
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) C1700 Software (C1700-Y7-M), Version 12.3(6), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 11-Feb-04 20:25 by kellythw
Image text-base: 0x80008120, data-base: 0x80B03574
cisco 1760 (MPC860P) processor (revision 0x500) with 180224K/16384K bytes of mem
ory.
Processor board ID FOC08091TM8 (1490004140), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
65536K bytes of processor board System flash (Read/Write)
         --- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
and these are the flash contents, as it seems to me, all is in good order >
C1760#show flash:
System flash directory:
File  Length   Name/status
  1   6703344  c1700-y7-mz.123-6.bin
  2   1888     sdmconfig-1751-1760.cfg
  3   16264    sdm.shtml
  4   3176448  sdm.tar
  5   1462     home.html
  6   216064   home.tar
[10115856 bytes used, 56993008 available, 67108864 total]
C1760#
Simon Leigh
Once the router has booted do a 'sh ver'
At the end it should show the config register which should be 0x2102
It it is not run the 'configuration-register 0x2102' then save the config by doing a 'wr mem'
Reload the router at all should be good.
Tom Watts
Hi Dennis, did you write mem (copy run start..?)
use the command wr mem then reload and see what happens.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
glen.grant
Check the config register, for most models it should be 0x2102 . If not then change it and reload.
Simon Leigh
Dennis Wieringa
this was the issue iv'e apparently got.
i ran first the wr mem from Tom Watts, but remembered that there also could be an conf register problem.
so i changed it into 0x2102 and all was well again
thanks everyone for the help
