IP address for 2nd router ?
Hi all, this may be a simple answer to my problem but any help appreciated.
I've got Sky broadband coming into my home network.
Sky comes into router 1 & I can navigate to this using a browser 198.162.0.1 etc
I have a cat5 running from that router to a Cisco router in my office & an IP camera running off that.
To set up the IP camera, I need to configure it via a browser, but how do I know the IP address of the 2nd router or the IP camera ?
Thanks in advance.
Layer_Two
Your old ip address should work... If it doesnt work, you can use a lan scan tool to find all ip running on your network... Try googling lanscan... Plenty of free stuff on the net
Layer_Two
Thank you.
