02-15-2007 07:58 AM - edited 03-05-2019 02:22 PM
I have 2611-XM. I have a FastEthernet Module connected on it with 16 ports.
Everytime i try to configure the IP address on the FastEthernet , i keep getting this error % IP addresses may not be configured on L2 links".
When i do "show vlan-switch" i do see all the FastEthernet's are under VLAN-1. I do not want these ports to be under VLAN-1. Is there a way i can individually configure the IP addresses on these FastEthernets. I removed the VLAN-'s but still didn't work. Any ideas, help or documentation would be appreciated.
Hassan.
02-15-2007 08:13 AM
You cannot put an address on the switchports , you must create a layer 3 SVI and then put the ports into that vlan .
02-15-2007 08:18 AM
Hello Glen,
What you are saying. I should define VLAN's and then assign the FastEthernet Ports to these VLAN's. Right...
02-15-2007 09:02 AM
No Glenn meant you need to make your interfaces as L3 SVI and then assign an IP address to it.
Do this -->
conf t
int
no switchport
ip address x.x.x.x x.x.x.x
or if you want the port to be a member of VLAN, do this-->
conf t
int vlan
int
switchport access vlan
Have a look the following link -->
Let us know more clearly what are you trying to do, so that we can help you better.
Hope this helps...
AbhisheK
Please rate all helpful posts!!!
02-15-2007 09:22 AM
Hello Abhishek,
Actually, i can create a VLAN-40 and assign the Ip address to this VLAN-40. Then under Fas 1/0 i can put 'switchport access vlan 40'.
When i do "sh vlan-switch" because this is 2611-XM. i do see that VLAN's so i created a new VLAN, which is VLAN-40.
But i was just wondering is there a way for me to individually assign the IP addresses on my FastEthernet interfaces, rather then combining them into different VLAN's. I did tried under FastEthernet " no switchport" then try to assign it. But it didn't take it.
Could this be due to the IOS c2600-jz-ms..not sure any help will be apprecaited.
05-19-2017 04:27 AM
Thank you for this explanation!!!!
Ratnavo Dutta
04-10-2025 02:21 AM
02-19-2019 07:16 PM
Try this:
configure terminal
int fax/x
no switchport
no shutdown
ip address X.X.X.X (ip) X.X.X.X (subnet mask)
end
then you can check the configuration:
show ip interface brief
where you are going to be able to look at the status of the interfaces and the ip addresses. The command no switchport basically bring the L2 interface to a routable link (L3).
