ip default-gateway and default-information originate
mahesh18
Level 6
Level 6
Hi Everyone,
Currently our 3750 switch has below config
Current Switch running ospf
ip default-gateway x.x.x.x
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.x
router ospf 1
default-information originate metric 10 metric-type 1
As I need to change the network design we want some other switch in network to advertise the default route config
New Switch running ospf
router ospf 1
But we want current switch even if it learn the default gateway from the nei switch it should follow the current ip default gateway  x.x.x.x
So my question is even if current switch learn the default route via ospf nei will config ip default gateway take priority over it?
MAhesh
4 Accepted Solutions
Hi Mahesh,
On current 3750 I need to remove the default information originate command that is for sure.
That is fine but remember if you remove that, you will lose your outbound Internet redundancy because all the devices will only learn one default route (from the new switch)  and out Internet2. So, if for example, the connection between the core switch and the new 3750 fails, the traffic has no where to go and cannot reach Internet1 since there is no other default route to learn.
If I remove the OSPF then how current switch will communicate with immediate connected switch?
You have to use static routes.
Is there any command that we can run on 3750 so that we can see if we remove ospf then which static
routes we need to add?
You just need to look at the current routing table and whatever routes you are learning from the firewall and the current switch need to be replaced with static routes. So, on the current 3750, you need static routes to learn all the routes you are learning from OSPF which is from the core switch and the new switch.
So again is there any way we can keep running ospf on current switch and make sure it has static route
route 0.0.0.0/0 next hop firewall
Yes, you can simply add route 0.0.0.0/0 next hop firewall and delete the default-information originate command from OSPF but again you will lose the redundancy because there isn't a second default route on other devices routing table. So, everything else besides the current switch and the firewall on left will always go out Internet2.
Yogi-Bear
Just remove default information originate on current and youre good to go.
If you use both the ip default-network and ip route 0.0.0.0 0.0.0.0 commands to configure candidate default networks, and the network used by the ip default-network command is known statically, the network defined with the ip default-network command takes precedence and is chosen for the gateway of last resort
Hi Mahesh,
redistribute static subnets is not going to redistribute the default route into OSPF.  You need  default-information originate command.
https://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/47868-ospfdb9.html
Hi Mahesh,
That is correct.
17 Replies 17
Reza Sharifi
Hi Mahesh,
In this case, the ip default gateway command will not be effective since you already have a default route pointing to the same ip next hop.
In addition, the ip default gateway command is usually used for layer-2 switches with no routing enabled.
Hi Reza,
I need to remove the below config from the current switch
This is what I want to achieve on current switch I do not want to point to the new default gateway learned by new new switch(default information originate)
I want that current switch should use its current default gateway and do not advertise that to ospf.
Mahesh
Hi Mahesh,
The default route should be advertised from the closest device to the Internet. So, if the new switch you are deploying is the closest switch to internet and is advertising a default route to the current switch, you can simply remove the commands you listed from the current switch and the current switch will run OSPF and get the default route from the new switch.
Is that what you are trying to do?
Maybe a simple diagram can clarify it.
Yes that is one part of story.
i have attached the network diagram.
where diagram on left is current one and diagram on right hand side is new one.
what i need is that if i remove the ip route 0.0.0.0/0 and default information originate command from current network and advertise on new switch.
Then on current switch i want that users going to DMZ network follow the same path not the new network.
what i want is that current switch it it do not know any network route it should point to fw as next hop
On your diagram, both sides look exactly the same.  I don't see anything new. What am I I missing?
Is the whole diagram all one network with redundant connections (access, disto, core, etc..) or you only have the left side and trying to add the right side to the network?
Can you clarify?
sorry for cauisng the confusion.
i have modifies the diagram please take look now.
all we want is that to advertise the default route to internet from new switch connected to the firewall from right hand side.
So that all the ospf routers can learn the default gateway.
that thing has no issues.
my only concern is that current 3750 switch should not listen to the new default route and it should still
point to the firewall for default gateway as we have many networks behind the dmz.
MAhesh
Hi Mahesh,
How about this:
Advertise a default route from the new switch on the right side, so all traffic from the core, distro, and access switch take that path and go out Interner2. Then on the left side have the firewall advertise a default route to the current 3750 switch, so all traffic from DMZ take that path and go out Internt1. Now don't run OSPF between the current 3750 and the core switch and just use static routes this way the current 3750 does not see the default route from the new switch.
You can also keep the same setup with one default route from the current 3750 and one from the new 3750 and use a higher metric on one of them to make it less preferable. For example, the current 3750 would prefer to go out using Internet1 and use the Internet2 as its backup.
Hi Reza,
Other thing for now I need OSPF running on current switch  if my change goes south.
and this do not get advertised into ospf then in that case this current 3750 switch will not use the new
default route learned.Can we used some route map to make this happen?
Hi Mahesh,
Yogi-Bear
Yogi-Bear
Hi Bobby,
Thanks for replying to the post.
So i will remove the default information originate from the current switch.
As you say if i leave below config
 ip default-network
Then current switch will use ip default-network over ip route o.o.o.o/o?
Also under ospf i have this config
will this cause the ip route 0.0.0.0 0.0.0.0 next hop command to be advertised to ospf?
Mahesh
Hi Mahesh,
Hi Reza,
One last thing to confirm if this current switch learns the default route via ospf then it will still prefer the
static route 0.0.0.0/0 configured on it as it has lower metric right?
Best Regards
Mahesh
