ip default-gateway and default-information originate
mahesh18
Level 6
Level 6
Hi Everyone,
Currently our 3750 switch has below config
Current Switch running ospf
ip default-gateway x.x.x.x
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.x
router ospf 1
default-information originate metric 10 metric-type 1
As I need to change the network design we want some other switch in network to advertise the default route config
New Switch running ospf
router ospf 1
But we want current switch even if it learn the default gateway from the nei switch it should follow the current ip default gateway  x.x.x.x
So my question is even if current switch learn the default route via ospf nei will config ip default gateway take priority over it?
MAhesh
17 Replies 17
Hi Mahesh,
That is correct.
Hi Reza,
Many Thanks for replying to all my questions.
I can always count on you.
Best Regards
Mahesh
