routing duplicate
below is existing route. Can i just remove everthing that have "name new-proxy" in it, seem duplicate
mlund
Level 11
Level 11
All routes that is marked with a name has the same next-hop destination as the default route. So yes, You can call that a duplicate because they route the packets to the same destination.
So for packet forwarding, if you delete them, the packet forwarding will use the default route instead.
/Mikael
Hi Mate,
Mikael has given you an appropriate answer and I haven't looked enough before i reply
**Removed**
Prabath
***Please rate all the useful posts***
-Prabath
mlund
Level 11
Level 11
/Mikael
Yup, i have deleted the duplicate entry
