01-07-2019 11:53 PM - edited 03-08-2019 04:58 PM
I have a Cisco 4503 with Software version 03.03.00.SG. I have a dhcp pool name with spaces, i'm unable to manage this pool, or delete it.
ip dhcp pool AAA Gxxx Wi-Fi
I get the following error when trying
Invalid input detected at '^' marker.
appreciate any help.
01-08-2019 12:03 AM
That is not correct syntax to use.
refer below command reference :
you mentioned you can not delete ? can you post your configuration ?
01-08-2019 12:08 AM
01-08-2019 12:08 AM
Hello @shelly mathew,
I don't fully understand,
But if you want to create that dhcp pool, the spaces will not be accepted!
Instead I usually use _
So you can create it using:
ip dhcp pool AAA_Gxxx_Wi-Fi
Please don't forget to rate all helpful responses!
Bsr Rgds,
Andrew Khalil
01-08-2019 12:10 AM
01-08-2019 12:12 AM
Try:
no ip dhcp pool AAA_Gxxx_Wi-Fi
Bst Rgds,
Andrew Khalil
01-08-2019 12:15 AM
01-08-2019 12:21 AM
@shelly mathew that error you have attached, it's when you configure new dhcp pool,
Anyway, try to type no then copy paste the exact written command, but by copying and pasting not by typing!
and share with us a screenshoot of the results!
Bst Rgds,
Andrew Khalil
01-08-2019 12:24 AM - edited 01-08-2019 12:31 AM
01-08-2019 12:34 AM
It's weird!
Try to reload the switch and check !
if not, maybe you can factory reset it and reconfigure it!
Please don't forget to rate all the helpful responses!
Bst Rgds,
Andrew Khalil
01-08-2019 12:36 AM
01-08-2019 12:42 AM
What terminal software are you using?
Is it a console cable connection or SSH or telnet?
Maybe you try to change the terminal software, maybe there is a hidden character between the words but we don't know it? also if you are connected through console try by telnet or vice versa!
Bst Rgds,
Andrew Khalil
01-08-2019 12:43 AM
01-08-2019 12:58 AM
01-08-2019 08:38 AM
At this stage can you post running config to have a look ?
what kind of tool you using to connect ?
