ip pim sparse-mode on Vlan interface
harryraju
I'm trying to configure "IP PIM SPARSE-MODE" command on a vlan interface on a 3560E switch but it doesn't give me the option to do this. The only option available is ip pim passive. What would cause this ? On the same switch a physical interface is already configured with IP PIM SPARSE-MODE.
Peter Paluch
Hello Harry,
What license do you have running on your 3560E? I vaguely recall that a basic license or feature set for 3560E Catalysts supports only the PIM Stub routing which is why you see only the ip pim passive command. You would probably need to upgrade your license/feature set to get full multicast routing support.
Best regards,
Peter
Peter Paluch
Hello Harry,
Best regards,
Peter
Thanks Peter. And looks like you are right . This artical explains it under PIM Stub routing
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/software/release/12.2_58_se/configuration/guide/swmcast.html#wp1127349
and the switch is running just ipbase so looks like a upgrade it in order. Thanks for you help.
