10-07-2011 03:05 AM - edited 03-07-2019 02:39 AM
I have a one no of cisco 3750 switch, i have server at other location(Location A) ip address is 172.16.1.1/24.
At my side (Location B) i have using defferent ip range 192.168.1.0/24. I have FO connectivity from Location A to Location B
i have configure the switch like this..
interface vlan 1
interface vlan 2
ip address 172.16.1.100 255.255.255
ip route 0.0.0.0 0.0.0.0 172.16.1.1
i can ping to the server (172.16.1.1) from switch console, but i can't ping from the users (which is connected 192.168.1.0 network) ont thing is that i can ping 172.16.1.100.
10-07-2011 03:26 AM
Is the connection to Location A a L2 link or a L3 routed link ?
What is 172.16.1.1 ?
Can you post details of how Location A is configured ?
Jon
10-07-2011 03:36 AM
Connection to Location A is L2 link.
172.16.1.1 is one of the server address of Location A, i want to access it from Location B.
Location A is separate network, i have just want to access the perticular server (172.16.1.1) from Location B.
Debabrata
10-07-2011 04:06 AM
Not sure you need that default-route ie.
Apart from that, what is the default-gateway set to on the server ? it should be 172.16.1.100
Edit - just noticed that your subnet mask on vlan 2 is wrong. It should be 255.255.255.0 and not 255.255.255.255
Jon
10-07-2011 04:13 AM
To enable routing on the switch Layer 3, you must enable ip routing in the global configuration mode.
C3750-1(config)#ip routing
C3750-1(config)#sh run...
switch 1 provision ws-c3750x-48
system mtu routing 1500
ip routing
10-07-2011 04:25 AM
Question A . What address range (subnet) are you using for your connecting link across the fiber?
Question B. Are you using dynamic routing protocols ? If not then you will need static routes on both sides pointing from one side to the other.
10-17-2011 11:05 PM
Dear
172.16.1.0/24 location A
192.168.1.0/24 location B
At my site (location B) is possible to create a static route but the another site (location A) is not possible to configure static route, because there in no router at location A, all are L2 devices. Just tell me is it possible to do without any changes at Location A ?
Debabrata
10-18-2011 12:02 AM
Hi Debudas
As mentioned by Jon above the Subnet Mask of Vlan 2 should be /24 not /32. If Site B users in the Subnet 192.168.1.0/24 wants to access 172.16.1.0/24 Subnet Server then we need to do intervlan routing at Site B Router ie using router on stick model.
Why you have a default-route on the Switch at Site A pointing to the Server . Are you able to remote access your L2 Switch at Site A apart from Router B. I believe you would not be able to do so. If its a L2 Switch and we don't need a default-route but instead a default-gateway poiting to MGMT VLAN IP on Site B Router.
Your final setup should look like this as below:
Router-Site-B
dot1q-1 dot1q-2
192.168.1.x/24 172.16.1.x/24
Trunk Link (Vlan 1,2)
L2 Switch-Site-A
SVI-1 SVI-2
192.168.1.1/24 172.16.1.100/24
L2 Switch-Site-A (default-Gateway either 192.168.1.X or 172.16.1.X depends on MGMT VLAN)
Access(Vlan 2)
Server
IP-172.16.1.1/24, Default-Gateway 172.16.1.x
Hope this helps you to clarify your answer.
Varma
