IP Routing on 3550
ddaugherty1264
Starting point: 8-3550 Switches, 1-2811 router (10.2.232.250), all on one subnet 10.2.232.0:255.255.252.0, one VLAN=1. ALL WORKS FINE.
I'm adding VLANs and I need to enable routing on the switches for Inter-VLAN routing. However, when I enable ip routing on the frist switch, the 'network' still works (stations work fine) however, in about 3 minutes, I can no longer HTTP nor ping the VLAN 1 interface. I'm guessing the 3 min delay is routing info updating. I can't even reach it on the switch itself. So, I can't manage it in Network Assistant, nor the web interface. I can still get to any other switch VLAN interface.
Here is before conf info:
no ip subnet-zero
no file verify auto
spanning-tree mode pvst
spanning-tree portfast default
vlan internal allocation policy ascending
interface Vlan1
ip address 10.2.232.203 255.255.252.0
ip default-gateway 10.2.232.250
ip classless
ip http server
Here is after:
no ip subnet-zero
ip routing
no file verify auto
interface Vlan1
ip classless
ip route 0.0.0.0 0.0.0.0 10.2.232.250
ip http server
This driving me crazy and not a good experience with ip routing on the 3550. It probably comes down to me misconfiguring something, but I don't know what.
Please assist and I will be singing praises about you!
Thanks.
29 Replies 29
Richard Burts
Don
In looking at what you posted it looks like these are the only things that are different:
ip routing
I do not see what about these 2 additions would cause the symptoms that you describe. Is it possible that you have changed anything else?
As a check on the problem, if you remove these 2 statements does the behavior go back to what it used to be?
Also I am not clear whether PCs connected to this switch still work (it is only a problem getting to the management interface of the switch) or does everything on this switch stop working?
Rick
Rick
aravindhs
Why do you need the entry 'ip default-gateway 10.2.232.250 ' on the router after you have enabled routing ?
cheers
Arav
Arav
I am not sure that you "need" the ip default-gateway when ip routing is enabled. But it does no harm and sometimes you may want to have it. In a few circumstances (most especially operating in rommon) the router is not routing and the ip route 0.0.0.0 does you no good. But the ip default-gateway does work in that situation.
So for normal operation the ip default-gateway is not used. But it is cheap and easy insurance to cover you in certain problem situations.
Rick
Rick
The only changes are these.
And if I remove them and RESTART the switch all is back to normal. If I remove and clear routes, it still is hosed.
All PCs work without a hitch. The only problem is management.
Strange, huh?
Just for grins, here is the entire configs. OOPS, there is one more change: in VLAN1 added, "no ip route-cache"
Just for more info, these changes were created by Network Assistant. I am running 12.2(35)SE-IP-BASE on all switches.
BEFORE:
version 12.2
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service sequence-numbers
hostname ICUSwitch1.net.fleming.org
enable secret 5 ####
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos min-reserve 5 170
mls qos min-reserve 6 85
mls qos min-reserve 7 51
--More-- mls qos min-reserve 8 34
mls qos
no ip subnet-zero
no file verify auto
interface FastEthernet0/1
switchport mode dynamic desirable
interface FastEthernet0/2
interface FastEthernet0/3
switchport mode trunk
--More-- mls qos trust cos
macro description cisco-switch
auto qos voip trust
wrr-queue bandwidth 10 20 70 1
wrr-queue min-reserve 1 5
wrr-queue min-reserve 2 6
wrr-queue min-reserve 3 7
wrr-queue min-reserve 4 8
wrr-queue cos-map 1 0 1
wrr-queue cos-map 2 2 4
wrr-queue cos-map 3 3 6 7
wrr-queue cos-map 4 5
priority-queue out
spanning-tree link-type point-to-point
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
--More-- !
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
--More-- switchport mode dynamic desirable
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
--More-- interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip classless
ip http server
I did remove the SNMP stuff at the bottom for posting a message space issues.
AFTER:
version 12.2
no service pad
no aaa new-model
mls qos
no ip subnet-zero
no file verify auto
auto qos voip trust
priority-queue out
--More-- !
interface Vlan1
ip classless
ip http server
Don
I do like the idea of seeing the entire config and think that it may be helpful.
Is it possible that you have posted the same config as before and as after? Unless my eyes deceive me I am not seeing any difference in the 2 configs that you posted.
And it is helpful to know that it only impacts the management address of the switch, so that all PCs continue to work as they should. Would I be correct in assuming that the PC default gateway is still configured as the router address?
Do I understand that when you make the change that you still have access to the switch for a few minutes and then you no longer have access?
Rick
Rick
Sorry about this. Yes, the PCs continue to work (forever). Yes, the PCs default g/w is the router. Yes, I do have access to the switch for about 3-4 minutes, then it goes away.
You guys are really going to think I am ate up. But this is what happens when you append logs together.
The following is really, the real after:
version 12.2
no service pad
no aaa new-model
mls qos
no ip subnet-zero
ip routing
no file verify auto
--More-- switchport mode trunk
mls qos trust cos
auto qos voip trust
priority-queue out
--More-- interface FastEthernet0/14
--More-- !
interface Vlan1
ip classless
ip http server
Don
Thanks for posting the correct after version of the config. I have looked at it and do not see anything that seems to explain what is going on.
From the fact that after you make the change you still have access for several minutes it may be reasonable to assume that something is timing out. I wonder if you made the change and when it stopped working if you clear the ARP cache - first on the switch and then if needed on the router - if it might fix it.
If clearing the ARP does not make a difference then I would probably look into the mac address table on the switch. It might help to show mac-address-table, before the change, after the change, and after connectivity is interrupted.
Rick
Rick
Check the vlan 1 interface of the switch. The line may be "up" but the protocol may be "down". If this is the case, you must have an active client connection on vlan 1 for the SVI to go to an up/up condition . Once there is a live client on the switch you will see vlan 1 up/up.
glen.grant
It is working correctly . When you turn on ip routing you cannot use the ip default-gateway command , you must use a static default route , not sure why you are turning on ip routing but that is another story . The reason everything else works is that is appears you are trunking to another layer 3 device which is the default gateway for your subnets , so all the clients have their default gateways pointed to that address so they would keep working as they are not pointed to anything on the problematic 3550. I think everything will normalize if you pull the ip default gatway command and add the default static route 0.0.0.0 0.0.0.0 10.2.232.250 . Is there some reason you feel you have to turn on ip routing ?
Glen
The posted config clearly shows that a static route for 0.0.0.0 has already been configured.
Your assertion that the ip default-gateway may be causing the problem is not correct. I frequently configure layer 3 devices with ip default-gateway and it does not cause problems. You are correct that when the device is acting as a router (ip routing enabled) that the default-gateway is not used. But if the device is not routing (for example in rxboot) then the ip default-gateway would be used.
Rick
Rick
The IP default gateway command has absolutely no effect if IP routing is enabled. Once ip routein
