IP sla 1 opttions
jfeo
I have a 4507 running Version 12.2(52)SG and I am trying to ip sla  reachability  however that feature isn't available on this version do I need to upgrade the switch to a new IOS or another way of doing this?
Reza Sharifi
Sla object tracking is supported in IOS XE with IP Base license.
have a look at this link:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1/XE_330SG/configuration/guide/config/sweot.html#wp1085002
I have a WS-C4507R and this is what i see
4507(config)#ip sla ?
key-chain Use MD5 authentication for IP SLAs control message
responder Enable IP SLAs Responder
4507(config)#ip sla
Have a look at this document.
The IP SLAs responder can be a Cisco IOS Layer 2, responder-configurable switch, such as a Catalyst 4500 running the IP base image. The responder does not need to support full IP SLAs functionality.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/46sg/configuration/guide/Wrapper-46SG/swipsla.html#wp1085020
