03-25-2009 10:27 AM - edited 03-06-2019 04:48 AM
we have 6509-E switch and SUP-720-3B.
s72033-ipservicesk9_wanmz.122-33.SXH3a.bin, this IOS does not support this module WS-X6066-SLB-APC but support IP SLA.
WHEN we have changed this IOS to this IOS
s72033-adventerprisek9_wan-vz.122-18.SXF15a.bin card (WS-X6066-SLB-APC )is supporting. but IP SLA commnads are not supporting as per cisco this version 12.-18.sxf support IP SLA.
this is a peculiar issue plse sugget ,what can be done on this ...plse provide any IOS which can support this card and IP SLA together...or provide any such cisco document which confirm the any limitation regarding hardware or IOS ,plse provide link or doc so we can check the same.
also we have tried so many other IOS but IP SLA commands are not taking if we go for 122-33.sxh than above module is not supported but in cisco tool IP SLA supported in each verion.
Vaibhav
03-25-2009 11:21 AM
Vaibhav,
You can use rtr which is the previous version of ip sla
#do show ver | i SXF
IOS (tm) s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)SXF8
#rtr ?
<1-2147483647> Entry Number
key-chain Use MD5 authentication for RTR control message
low-memory Configure low water memory mark
reaction-configuration RTR Reaction Configuration
reaction-trigger RTR Trigger Assignment
reset RTR Reset
responder Enable RTR Responder
restart Restart an Active Entry
schedule RTR Entry Scheduling
http://www.cisco.com/en/US/docs/ios/ipsla/command/reference/sla_03.html#wp1023731
HTH,
__
Edison.
03-25-2009 12:18 PM
Hi Edison
thats mean Above suggested image is support all the features of IP SLA as well as supports the mentioned card.
also plse let us know about my query is their any document which suggest that 122-18.sxf support IP SLA. ANY SUCH DOCUMNET WHICH IS TELLING ABOUT LIMITATION IN THIS RELEASE OR ANY OTHER WORKARROUND.
Vaibhav
