ip sla on 2960
naimtahir
I am trying to find out which 2960 supports IP SLA source feature. Currently i am running it on WS-C2960-24PC-L which is end of sale. i need to know which new 2960 support this functionality. I bought two switches (WS-C2960+24TC-L and WS-C2960+24LC-L) but both of them only support responder functionality. Below is my current IP SLA config working on WS-C2960-24PC-L which i need to run on new one.
ip sla 100
udp-jitter x.x.x.x 17000 source-ip Y.Y.Y.Y codec g729a codec-numpackets 500 codec-size 16 advantage-factor 20
tos 192
tag remote_site
ip sla schedule 100 life forever start-time now
Remote_Site#show ip sla statistics
Round Trip Time (RTT) for Index 100
Latest RTT: 665 ms
Latest operation start time: 10:06:31.752 EDT Thu Jun 15 2017
Latest operation return code: OK
RTT Values
Number Of RTT: 499
RTT Min/Avg/Max: 645/665/843 ms
Latency one-way time milliseconds
Number of Latency one-way Samples: 499
Source to Destination Latency one way Min/Avg/Max: 330/339/378 ms
Destination to Source Latency one way Min/Avg/Max: 312/325/510 ms
Jitter time milliseconds
Number of SD Jitter Samples: 497
Number of DS Jitter Samples: 497
Source to Destination Jitter Min/Avg/Max: 0/7/46 ms
Destination to Source Jitter Min/Avg/Max: 0/7/163 ms
Packet Loss Values
Loss Source to Destination: 0 Loss Destination to Source: 1
Out Of Sequence: 0 Tail Drop: 0
Packet Late Arrival: 0 Packet Skipped: 0
Voice Score Values
Calculated Planning Impairment Factor (ICPIF): 15
Mean Opinion Score (MOS): 3.92
Number of successes: 46
Number of failures: 0
Operation time to live: Forever
ah ok that's why its not there , I don't think I have any plus models to check all S or standard were moving away from 29.. series so we haven't bothered replacing them
I checked the feature navigator too and it hasn't updated the 2960 plus its there but showing nothing for your image and I see there are no v12s available for that model  only v15
when I check the data sheet the plus series does not look to support it at all like you said just responder
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-plus-series-switches/qa_c67-728215.html
the plus version is also the replacement for the current 2960s all of them looking at the doc , you might be out of luck here , a new 2960 may not support it at all anymore
WS-C2960-24TC-L
Catalyst 2960 24 10/100 + 2T/SFP LAN Base Image
WS-C2960+24TC-L
Catalyst 2960 Plus 24 10/100 + 2T/SFP LAN Base
7 Replies 7
Mark Malone
works fine on my WS-C2960-24TC-L with lanbase license , what license you running
You can also check the software navigator it can help too
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/index.jsp
(config-ip-sla)#do sh ver | i LAN
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(55)SE8, RELEASE SOFTWARE (fc2)
*    1 26    WS-C2960-24TC-L    12.2(55)SE8           C2960-LANBASEK9-M
(config-ip-sla)#ip sla 1
(config-ip-sla)#?
IP SLAs Entry configuration commands:
  dhcp         DHCP Operation
  dns          DNS Query Operation
  exit         Exit Operation Configuration
  ftp          FTP Operation
  http         HTTP Operation
  icmp-echo    ICMP Echo Operation
  path-echo    Path Discovered ICMP Echo Operation
  path-jitter  Path Discovered ICMP Jitter Operation
  tcp-connect  TCP Connect Operation
  udp-echo     UDP Echo Operation
  udp-jitter   UDP Jitter Operation
Hey Mark,
Thank you for your response. here is the version detail
Switch#sh ver | i LAN
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 15.2(2)E6, RELEASE SOFTWARE (fc1)
* 1 26 WS-C2960+24TC-L 15.2(2)E6 C2960-LANBASEK9-M
Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#ip sla ?
key-chain Use MD5 Authentication for IP SLAs Control Messages
responder Enable IP SLAs Responder
Im running following IOS
c2960-lanbasek9-mz.152-2.E6.bin
Looks like i need to downgrade. can you share your image file name also.
ah.. yours is C2960-24TC-L and mine is WS-C2960+24TC-L ... (plus)
looks like yours is also end of sale.
http://www.cisco.com/c/en/us/support/switches/catalyst-2960-24tc-l-switch/model.html
let me know if i'm missing something :)
WS-C2960-24TC-L
WS-C2960+24TC-L
Thanks mark for the details response!
Would you suggest any other replacement of 2960 in the same price range?
we need up to 16 ports. and basic static routing and vlans with IPSLA feature.
I suppose that's the problem all the 2960s are eol now as below in next 2years that currently do support ip sla and there all being replaced with 2960 plus which only does responder so if ip sla is the tie breaker you might want to look at something else like 3650 they definitely support all feature as there dist level switches , it depends as well if you want it under active support with Cisco if not an non plus model should do for you rather than forking out for  3 series
checking the compact switches there the same and even the X series is only responder too , that's all the 29 series
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_4_e/configurationguide/b_1524e_consolidated_2960x_cg/b_1524e_consolidated_2960x_cg_chapter_01010110.pdf
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-series-switches/eos-eol-notice-c51-730121.html
End-of-Sale Product Part Number
Product Description
Replacement Product Part Number
Replacement Product Description
Additional Information
WS-C2960-24-S
Catalyst 2960 24 10/100 LAN Lite Image
WS-C2960+24TC-S
Catalyst 2960 Plus 24 10/100 + 2 T/SFP LAN Lite
WS-C2960-24LC-S
Catalyst 2960 24 10/100 (8 PoE) + 2 T/SFP LAN Lite Image
WS-C2960+24LC-S
Catalyst 2960 Plus 24 10/100 (8 PoE) + 2 T/SFP LAN Lite
WS-C2960-24LT-L
Catalyst 2960 24 10/100 (8 PoE)+ 2 1000BT LAN Base Image
WS-C2960+24LC-L
Catalyst 2960 Plus 24 10/100 (8 PoE) + 2 T/SFP LAN Base
WS-C2960-24PC-L
Catalyst 2960 24 10/100 PoE + 2 T/SFP LAN Base Image
WS-C2960+24PC-L
Catalyst 2960 Plus 24 10/100 PoE + 2 T/SFP LAN Base
WS-C2960-24PC-S
Catalyst 2960 24 10/100 PoE + 2 T/SFP LAN Lite Image
WS-C2960+24PC-S
Catalyst 2960 Plus 24 10/100 PoE + 2 T/SFP LAN Lite
WS-C2960-24TC-L
WS-C2960+24TC-L
WS-C2960-24TC-S
Catalyst 2960 24 10/100 + 2 T/SFP LAN Lite Image
WS-C2960+24TC-S
WS-C2960-24TT-L
Catalyst 2960 24 10/100 + 2 1000BT LAN Base Image
WS-C2960+24TC-L
WS-C2960-48PST-L
Catalyst 2960 48 10/100 PoE + 2 1000BT +2 SFP LAN Base Image
WS-C2960+48PST-L
Catalyst 2960 Plus 48 10/100 PoE + 2 1000BT +2 SFP LAN Base
WS-C2960-48PST-S
Catalyst 2960 48 10/100 PoE + 2 1000BT +2 SFP LAN Lite Image
WS-C2960+48PST-S
Catalyst 2960 Plus 48 10/100 PoE + 2 1000BT +2 SFP LAN Lite
WS-C2960-48TC-L
Catalyst 2960 48 10/100 + 2 T/SFP LAN Base Image
WS-C2960+48TC-L
Catalyst 2960 Plus 48 10/100 + 2 T/SFP LAN Base
WS-C2960-48TC-S
Catalyst 2960 48 10/100 + 2 T/SFP LAN Lite Image
WS-C2960+48TC-S
Catalyst 2960 Plus 48 10/100 + 2 T/SFP LAN Lite
WS-C2960-48TT-L
Catalyst 2960 48 10/100 + 2 1000BT LAN Base Image
WS-C2960+48TC-L
WS-C2960-48TT-S
Catalyst 2960 48 10/100 + 2 1000BT LAN Lite Image
WS-C2960+48TC-S
hmm that's odd its not in newer version
here you go
c2960-lanbasek9-mz.122-55.SE8.bin
https://software.cisco.com/download/release.html?mdfid=279963375&flowid=2547&softwareid=280805680&release=12.2.55-SE11&relind=AVAILABLE&rellifecycle=ED&reltype=latest
