IP-SLA
shelley_wang
Level 2
Level 2
Does anyone know how to configure ipsla such that cisco sends 2 pings packets before it marks the sla down?
thx,
Shelley
Jon Marshall
Shelley
Use the "delay down" option with IP SLA.
So if your ping frequency is 30 seconds then you would do -
ip sla reachability delay down 60
Jon
Hi Jon,
Thank you for your response. Currently the frequency/interval is set to 1 second. If delay down is set to 2 sec, the second ICMP Request is sent 1 second after the first Request before declaring reachability down.
Is it possible to send more than 2 ICMP Requests within each interval?
thx,
Shelley
Hi Jon,
I have a cisco 7600. It will send an icmp request every second. If the icmp response is not received, 3 consecutive icmp requests will be sent. SLA reachability down will be reported after all 4 icmp responses are not received. The following diagram illustrates my goal.
Sender
--------------------------------------- 0 second
-> 0 sec  (1st icmp Request is sent out)
-> 50ms  (no response, send 2nd icmp after timeout)
-> 50ms  (no response, send 3rd icmp after timeout)
-> 50ms  (no response, send 4th icmp after timeout)
    50ms  Report SLA reachability down
--------------------------------------- 1 second
--------------------------------------- 2 second
Question: will the following configuration achieve my goal?
ip sla 100
icmp-echo 10.32.24.1 source-ip 10.32.24.2
timeout 50
frequency 1
ip sla monitor reaction-configuration 100 react timeout threshold-type consecutive 3 action-type triggerOnly
thx,
Shelley
