ipsec AH in transport mode ,AH in tunnel mode
sarahr202
Level 5
Level 5
Hi everybody.
I am reading about Ipsec which contains two major protocols among others:  AH and ESP.
For now, I am focused on AH only. I read the theory on AH and two modes AH can operate :  Transport mode and tunnel mode.
(201.201.201.1)h1--------R1(199.199.199.1) s0--------------------------------------------------------s0(199.199.199.2)R2-------H2( 200.200.200.2)
I want to implement the following:
Every time R1 receives ip packet from H1 destined for H2, R1 should use AH in transport mode before it sends the packet out to R2, Similarly, R2 should use AH in transport for packets sent by H2 to H1, before sending them to R1.
I just need an example  as to how we can configure R1 and R2 to accomplish the above task..
Thanks for your help and have a great day.
7 Accepted Solutions
nkarthikeyan
Level 7
Level 7
Hi Sara,
Please find the configuration sample for the GRE IPsec VPN using transport mode.
(201.201.201.1)h1--------R1(199.199.199.1) s0---------------------------s0(199.199.199.2)R2-------H2( 200.200.200.2)
You can use the ACL to restrict only to the required ports that needed for the vpn like udp 500, ah, gre and 4500 and you can check. Hope this helps.
Also you can refer the belwo mentioned site for much better understanding about the differences between transport or tunnel mode.
R1:
version 12.4
hostname R1
ip cef
crypto isakmp policy 10
authentication pre-share
crypto isakmp key CISCO address 199.199.199.2
crypto ipsec transform-set MyTransSet esp-3des esp-sha-hmac
mode transport
crypto ipsec profile MyProfile
set transform-set MyTransSet
interface Tunnel0
ip address 10.10.10.1 255.255.255.252
tunnel source 199.199.199.1
tunnel destination 199.199.199.2
tunnel mode ipsec ipv4
tunnel protection ipsec profile MyProfile
interface serial0
ip address 199.199.199.1 255.255.255.0
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 199.199.199.2
line con 0
line aux 0
line vty 0 4
end
R2
version 12.4
hostname R2
ip cef
crypto isakmp key CISCO address 199.199.199.1
mode transport
interface Tunnel0
ip address 10.10.10.2 255.255.255.252
tunnel source 199.199.199.2
tunnel destination 199.199.199.1
interface serial0
ip address 199.199.199.2 255.255.255.0
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 199.199.199.1
line con 0
line aux 0
line vty 0 4
end
Please do rate if the given information helps.
By
Karthik
You can't configure that in Transport-mode. For IPSec (both AH and ESP) you have the following rule:
Transport-mode can only be used if the device that generated the packet also protects it and the device that verifies/decrypts it is the same that also processes the packet.
If you have security-gateways (R1 and R2) then you need two IP-headers. One for the end-to-end communication (with H1 and H2) and one for the gateway-to-gateway-communication (with R1 und R2).  But Transport-mode uses the original IP-header so that can't work.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
We want R1 to use AH in transport mode before sending out the above packet of s0. How can we configure AH in transport mode on R1 and R2?
You have to configure that the old way with crypto-maps. The tunnel-interfaces always use ipsec-tunnel-mode regardless what you configure in your transform-set.
Hi Sara,
I forget to mention the website info in my earlier post!!! Very welll explained scenario about the modes!!!
http://www.firewall.cx/networking-topics/protocols/870-ipsec-modes.html
By
Karthik
Hi Karthik,
The explaination of Transport-mode on that website is comlpetely wrong and shouldn't be referenced. Section 4.5 of RFC 2401 shows how the headers are build for tunnel- and transport-mode.
After being at the right PC now, here is an example for using AH with transport-mode (R1 shown, R2 is similar):
crypto isakmp key cisco address 2.2.2.2
crypto ipsec transform-set AH ah-sha-hmac
  mode transport
crypto map VPN local-address Loopback1
crypto map VPN 1 ipsec-isakmp
  set peer 2.2.2.2
  set transform-set AH
  match address VPN-R2
interface Loopback1
  ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
  crypto map VPN
ip route 2.2.2.2 255.255.255.255 10.10.10.2
ip access-list extended VPN-R2
permit ip host 1.1.1.1 host 2.2.2.2
And that is what flows over the wire with a ping:
Frame 14: 138 bytes on wire (1104 bits), 138 bytes captured (1104 bits)
Ethernet II, Src: ca:00:36:91:00:08 (ca:00:36:91:00:08), Dst: ca:01:36:91:00:08 (ca:01:36:91:00:08)
Internet Protocol Version 4, Src: 1.1.1.1 (1.1.1.1), Dst: 2.2.2.2 (2.2.2.2)
Authentication Header
    Next Header: ICMP (0x01)
    Length: 24
    AH SPI: 0x87018e79
    AH Sequence: 2
    AH ICV: 389141bfef53445fbd77452c
Internet Control Message Protocol
    Type: 8 (Echo (ping) request)
    Code: 0
    Checksum: 0x63fa [correct]
    Identifier (BE): 0 (0x0000)
    Identifier (LE): 0 (0x0000)
    Sequence number (BE): 2 (0x0002)
    Sequence number (LE): 512 (0x0200)
    [Response In: 15]
    Data (72 bytes)
0000  00 00 00 00 00 02 1a 4c ab cd ab cd ab cd ab cd   .......L........
0010  ab cd ab cd ab cd ab cd ab cd ab cd ab cd ab cd   ................
0020  ab cd ab cd ab cd ab cd ab cd ab cd ab cd ab cd   ................
0030  ab cd ab cd ab cd ab cd ab cd ab cd ab cd ab cd   ................
0040  ab cd ab cd ab cd ab cd                           ........
        Data: 0000000000021a4cabcdabcdabcdabcdabcdabcdabcdabcd...
        [Length: 72]
1) The "crypto-isakmp" commands don't specify to use tunnel mode or not. That's done in the "crypto ipsec transform-set". The ISAKMP-commands specify the parameters for the setup of the ISAKMP-tunnel. You can look at this tunnel as a management-connection between the two ipsec-peers. I skipped that because the router (starting with 12.4(20)T has usable defaults. You can see the defaults with "show crypto isakmp policy". The key is still needed to authenticate the connection-setup against Man-in-the-Mittle-attacks. Thats independent of using transport- or tunnel-mode.
2) The crypto-map is incomplete until you configure a "match address" and "set peer" statement. It just has to be there to work.
16 Replies 16
nkarthikeyan
Level 7
Level 7
Hi Sara,
R1:
version 12.4
hostname R1
ip cef
mode transport
interface Tunnel0
interface serial0
duplex auto
speed auto
line con 0
line aux 0
line vty 0 4
end
R2
version 12.4
hostname R2
ip cef
mode transport
interface Tunnel0
interface serial0
duplex auto
speed auto
line con 0
line aux 0
line vty 0 4
end
By
Karthik
Hi Karthik
R1:
mode transport
interface Tunnel0
interface serial0
duplex auto
speed auto
All the packets destined for 202.202.202.0 will be matched by static default route above which means R1 will use interface so to forward them.  ipsec will not be used because packets are not directed to tunnel configured on R1.
If we want all the packets destined for 202.202.202.0/24 network to use ipsec, we  must modify the static route above as shown below:
ip route 0.0.0.0 0.0.0.0 10.10.10.2 ( which is the next hop address from tunnel 0 on R1)
Am  I correct?
Thanks Karsten and Karthik.
I got it.  I am trying to understand how we can configure AH in transport mode on a router.
  R1(199.199.199.1)S0-----------------------------------S0(199.199.199.2)R2
R1 has Loopback1 1.1.1        R2 has   Loopback 2.2.2.2
R1 sends a ping packet with src ip 1.1.1.1 ,dst ip  2.2.2.2.
Thanks and have a great weekend.
Hi Karsten
mode transport
Above the mode is transport, if we do not specify the mode , what is the default mode ?
The default is tunnel-mode. That's what most of the time is needed on a vpn-gateway that protects the data of other systems.
Hi Sara,
By
Karthik
Hi Karthik,
Thanks karsten!!! let me check the rfc definition and explaination for the same!!!
HI Karsten,
Could you please explain me on the headers explained in rfc. I do not see any difference in opinion and am not sure if am missing anything.
RFC Says
Case 1. The case of providing end-to-end security between 2 hosts
across the Internet (or an Intranet).
H1* ------ (Inter/Intranet) ------ H2*
Note that either transport or tunnel mode can be selected by the
hosts. So the headers in a packet between H1 and H2 could looklike any of the following:
Transport Tunnel
1. [IP1][AH][upper]
4. [IP2][AH][IP1][upper] --> ( Method that explained in firewall forum)
2. [IP1][ESP][upper]
5. [IP2][ESP][IP1][upper]
3. [IP1][AH][ESP][upper]
Firewall forum says
ipsec-modes-transport-tunnel-6
The packet diagram below illustrates
IPSec Transport mode
with
AH header
ipsec-modes-transport-tunnel-4
The AH can be applied alone or together with the ESP when IPSec is in transport mode. AH’s job is to protect the entire packet, however, IPSec in transport mode does not create a  new IP header in front of the packet but places a copy of the original  with some minor changes to the protocol ID therefore not providing  essential protection to the details contained in the IP header (Source  IP, destination IP etc). AH is identified in the New IP header with an IP protocol ID of 51.
By
Karthik
Hi Karthik,
The line that you quoted in bold is from the right column in the RFC where the tunnel-mode is shown. Nr. 1) is what we are talking about at the moment:
1. [IP1][AH][upper]
And there the problem is with the diagram and the explaination from your referenced site. In transport mode, the original header is used. The AH is placed between the IP-header and the upper layers. But no copy of the original header is used.
That can be seen in the capture:
    Version: 4
    Header length: 20 bytes
    Differentiated Services Field: 0x00 (DSCP 0x00: Default; ECN: 0x00: Not-ECT (Not ECN-Capable Transport))
    Total Length: 124
    Identification: 0x0001 (1)
    Flags: 0x00
    Fragment offset: 0
    Time to live: 255
    Protocol: AH (51)
    Header checksum: 0xb548 [correct]
    Source: 1.1.1.1 (1.1.1.1)
    Destination: 2.2.2.2 (2.2.2.2)
    Length: 24
    AH SPI: 0x87018e79
    AH Sequence: 1
    AH ICV: aaed169f7013d8ae9a3f2a7e
    Code: 0
    Checksum: 0x640f [correct]
    Sequence number (BE): 1 (0x0001)
    Sequence number (LE): 256 (0x0100)
    Data (72 bytes)
There is no inner IP-header. Only the original one. ICMP (the upper layer in my capture) follows directly behind the AH. The Protocol number in the original header is changed to 51 (AH) and the next-header field in the AH shows the protocol ICMP which was in the original IP-header.
  mode transport
  set peer 2.2.2.2
interface Loopback1
  crypto map VPN
    Length: 24
    AH SPI: 0x87018e79
    AH Sequence: 2
    Code: 0
    [Response In: 15]
    Data (72 bytes)
        [Length: 72]
  Hi Karsten
Please  consider the partial configuration for tunnel mode below:
R1(config)# crypto isakmp policy 1
R1(config-isakmp)# encr 3des
R1(config-isakmp)# hash md5
R1(config-isakmp)# authentication pre-share
R1(config)#crypto isakmp key firewallcx address 1.1.1.2
above we have configuration related to formation of tunnel,( tunnel mode), According to above configuration,  all negotiations will be authenticated using md5, encrypted by 3des, and the other end of tunnel must be configured with key firewallcx in order to form tunnel with R1.
But now when i look at your example for implementing AH in transport mode,  I found:
1)My question is since we don't have a tunnel mode here, so what is the purpose of configuring the key" cisco " above ?
Please consider the partial configurations from your example:
set peer 2.2.2.2
2)I understand in tunnel mode the " set peer 2.2.2.2"  will cause router to use 2.2.2.2 as destination ip before packet is forwarded out of tunnel.  But why do we have " set peer 2.2.2.2" in above configuration for AH in transport mode?
I really appreciate your help.
thanks and have a great day.
