IPv6 RIP not being learned ME3600
k.ramalingam
            Hello Friends,
I have a very basic setup here but strange the router is learning RIP routes advertised by the switch but the switch is learning anyRIP routes. Debug shows the switch is sending updates but not receiving any. There is also these error:
%MRIB_API-3-ASYNC_ERR: Asynchronous error: failed to register to the MRIB. errno 0xE
I can ping across the gig 0/2 (switch) and GIg 0/2/0 (router)
sw01 - ME 3600
rtr1 - ASR 1001
sw01 config
ipv6 unicast-routing
ipv6 multicast-routing
ipv6 multicast rpf use-bgp
ipv6 router rip V6-RIP
interface GigabitEthernet0/2
description Link to rtr01-int-dc1 g0/2/0
no switchport
ip address yyyy
load-interval 120
delay 5000
ipv6 address yyyy
ipv6 enable
ipv6 rip V6-RIP enable
service-policy output Internet-policy
pv6 unicast-routing
ipv6 multicast vrf Mgmt-intf rpf use-bgp
interface Loopback10
description Router ID
ip address 103.16.193.251 255.255.255.255
ipv6 address 2406:3B00:1FFF:FFFF::2/128
ipv6 enable
interface GigabitEthernet0/2/0
description Uplink to g0/2.sw01-int-dc1
ip address 103.16.193.242 255.255.255.252
delay 5000
negotiation auto
ipv6 address 2406:3B00:1FFF:FFFE::2/125
ipv6 enable
cdp enable
no switchport
ip address 103.16.193.241 255.255.255.252
load-interval 120
delay 5000
ipv6 address 2406:3B00:1FFF:FFFE::1/125
ipv6 enable
Router configs
pv6 unicast-routing
delay 5000
negotiation auto
ipv6 address zzzzz
ipv6 enable
cdp enable
Any idea, why is this happening?
paolo bevilacqua
Seems a bug, complain to Cisco TAC.
Harold Ritter
Could you provide a "show ipv6 int ", "show ipv6 rip" and "show ipv6 rip data" from the two devices.
Thanks for your replies
sw01.int.syd#sh ipv6 rou interface gig 0/2
IPv6 Routing Table - default - 12 entries
Codes: C - Connected, L - Local, S - Static, U - Per-user Static route
       B - BGP, R - RIP, I1 - ISIS L1, I2 - ISIS L2
       IA - ISIS interarea, IS - ISIS summary, ND - ND Default, NDp - ND Prefix
       DCE - Destination, NDr - Redirect, O - OSPF Intra, OI - OSPF Inter
       OE1 - OSPF ext 1, OE2 - OSPF ext 2, ON1 - OSPF NSSA ext 1
       ON2 - OSPF NSSA ext 2
C   2406:3B00:1FFF:FFFE::/125 [0/0]
     via GigabitEthernet0/2, directly connected
L   2406:3B00:1FFF:FFFE::1/128 [0/0]
     via GigabitEthernet0/2, receive
sw01.int.syd#sh ipv6 rip
RIP process "V6-RIP", port 521, multicast-group FF02::9, pid 311
     Administrative distance is 120. Maximum paths is 16
     Updates every 30 seconds, expire after 180
     Holddown lasts 0 seconds, garbage collect after 120
     Split horizon is on; poison reverse is off
     Default routes are not generated
     Periodic updates 1162, trigger updates 6
     Full Advertisement 1, Delayed Events 0
  Interfaces:
    GigabitEthernet0/3
    Loopback10
    GigabitEthernet0/2
  Redistribution:
    Redistributing protocol bgp 132603 with metric 1 route-map IPv6_AAPT_Default_Route
sw01.int.syd#sh ipv6 rip dat
sw01.int.syd#sh ipv6 rip database ?
  |  Output modifiers
RIP process "V6-RIP", local RIB
and the routers:
rtr01.int.syd#sh ipv6 route interface gig 0/2/0
IPv6 Routing Table - default - 22 entries
       B - BGP, R - RIP, H - NHRP, I1 - ISIS L1
       I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary, D - EIGRP
       EX - EIGRP external, ND - ND Default, NDp - ND Prefix, DCE - Destination
       NDr - Redirect, O - OSPF Intra, OI - OSPF Inter, OE1 - OSPF ext 1
       OE2 - OSPF ext 2, ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2
       ls - LISP site, ld - LISP dyn-EID, a - Application
R   ::/0 [120/2]
     via FE80::F229:29FF:FE9B:ECC3, GigabitEthernet0/2/0
     via GigabitEthernet0/2/0, directly connected
L   2406:3B00:1FFF:FFFE::2/128 [0/0]
     via GigabitEthernet0/2/0, receive
R   2406:3B00:1FFF:FFFF::1/128 [120/2]
     via FE80::F229:29FF:FE9B:ECC3, GigabitEthernet0/2/0 rtr01.int.syd#sh ipv6 route interface gig 0/2/0
R   ::/0 [120/2]
Is rip enabled on any other interface other than gi0/2/0 on the ASR1k? Assuming that the asr1k loopback interface has an ipv6 address configured, could you try enabling rip in the loopback interface.
