IPv6 Stateless DHCP client does not get IP
gongya001
Level 5
Level 5
I am doing a small IPv6 stateless dhcp lab. But the client does not receive IP.  The configuration is as follows:
DHCP server:
ipv6 unicast-routing
int lo0
  ipv6 enable
  ipv6 add 2001:111::1:1:1:1/128
int e0/0
  ipv6 enable
  ipv6 add 2001:10::1/64
  no shut
int e0/1
   ipv6 enable
   ipv6 add 2001:11::1/64
ipv6 nd other-config-flag no shut ipv6 dhcp server IPv6Pool ! !DHCP Server ! ipv6 dhcp pool IPv6Pool dns-server 2002:555::1 domain-name foo.net
DHCP client
interface Ethernet0/1
 no ip address
 ipv6 address dhcp
 ipv6 enable
 no shut
Debug
*Aug 17 21:55:13.846: IPv6 DHCP: Received SOLICIT from FE80::A8BB:CCFF:FE00:B10 on Ethernet0/1
*Aug 17 21:55:13.846: IPv6 DHCP: Using interface pool IPv6Pool
*Aug 17 21:55:13.846: IPv6 DHCP: Creating binding for FE80::A8BB:CCFF:FE00:B10 in pool IPv6Pool
*Aug 17 21:55:13.846: IPv6 DHCP: Binding for IA_NA 00040001 not found
*Aug 17 21:55:13.846: IPv6 DHCP: Allocating IA_NA 00040001 in binding for FE80::A8BB:CCFF:FE00:B10
*Aug 17 21:55:13.846: IPv6 DHCP: Freeing IA_NA 00040001 from binding for FE80::A8BB:CCFF:FE00:B10
*Aug 17 21:55:13.846: IPv6 DHCP: Freeing binding for FE80::A8BB:CCFF:FE00:B10 from pool IPv6Pool
DHCP-S(config-if)#
*Aug 17 21:55:13.846: IPv6 DHCP: Sending ADVERTISE to FE80::A8BB:CCFF:FE00:B10 on Ethernet0/1
I don't see Received Request from the client.
What have I missed here ?
thanks !!
gongya001
Level 5
Level 5
found it out.
I missed ipv6 address autoconfig.
thanks !!
